Programming a '05 Tundra remote??
I've been searching like crazy to find instructions on how to program a key FOB for a '05 Tundra. We bought it as a demo and it came with no remotes. I bought the whole keyless entry system from e-bay just to use the remotes. Now all I need are the instructions. Please HELP!!!! :dunno:
It is a double cab. Factory system for all I know. The truck is out of town right now so I can't be any more specific. Thanks for your reply.
To add an additional remote on the DC factory system
1. Insert key into ignition key cylinder, then pull it out. (Assume from step 3 that driver door is open) Perform steps 2 & 3 Within 40 sec. 2. Press door lock control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. interval. 3. Close and open driver side door Perform steps 4 , 5, 6 & 7 Within 40 sec. 4. Press door lock control switch again (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. interval. 5. Insert key into ignition key cylinder. 6. Turn ignition switch from LOCK to ON and back to LOCK at approximately 1 second intervals, 1 time (This sets ADD Mode) 7. Remove key from ignition key cylinder. Within 3 sec, Body ECU automatically performs power door LOCK-UNLOCK operation to inform which mode has been selected. (1 LOCK-UNLOCK) Perform steps 8 & 9 Within 40 sec. 8. Press LOCK and UNLOCK switches on transmitter simultaneously within 1.5 sec. within 3 secs of step 8 perform step 9 9. Press either switch for more than 1.5 sec. Within 3 sec,Body ECU automatically performs power door LOCK-UNLOCK operation to show whether registration has been completed correctly or not. LOCK-UNLOCK Occurs Once - Registration of recognition code has been completed. LOCK-UNLOCK Occurs Twice - Registration of recognition code has failed. |
