99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Fabtek lift question
Old Jul 7, 2003 | 09:28 PM
fender1973's Avatar
I just had a 3" Fabtek suspension lift installed on my 2000 Tundra. The front boots closest to the transfer case spit a little bit of grease at exactly the same place on both sides. The boots are not torn anywhere. Do I need to replace the boots? They stopped spitting grease after a couple of days. Should I worry?
Old Jul 8, 2003 | 08:52 AM
Honger's Avatar
If they stopped spitting grease after a few days I'd be worried that there is no more grease in the boot... which is very bad! That means your CV joint will go bad soon!
I'm not a Tundra drive myself, but I know that other T100 drivers install manual hubs in the front (I will be doing so shortly) so that the CV joint is not functioning unless I put it in 4WD and lock the hubs.
You may try 4x4wire or TundraSolutions if you don't get any more information here.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
