99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Different Twist On Lift Gate Issue
Old Dec 14, 2012 | 11:19 AM
Sirecks's Avatar
Hey All,
I'm new to this forum, and really need an answer.
I've replaced the latch assembly on the rear lift gate a couple of times. I've taken the interior panel off many times to pull on the cable to actuate the latching mechanism to open the door. So I am very familiar with all that.
The problem I have today is that when I pull on the cable, there is a clanking sound from the latching mechanism/the lock (the lower part that actually latches, not the handle mechanism that you put your hand on to pull the cable) and the door won't open.
I have actually taken the ball end of the cable out of the arm that is attached to the handle and pulled on it with a pair of pliers. I'm not a small guy, so I was able to put some pressure on it and I can not get the lock to pop open. The cable travels about 2 inches or so, then stops with no further movement. There is a metal on metal clank sound each time the cable reaches the end of it's travels. The door is currently closed and I can't get it open as a result. I am unlocking the doors with the key, BTW.
I can not find a way to pop the rear hatch open in this situation.
Any ideas, or any experience with this?
Thanks,
Adam
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
RustBucket
Jul 24, 2015 04:46 AM
jackiebrownia
Jul 20, 2015 09:02 AM
crashburnoveride
Jul 10, 2015 06:39 AM
