Last edit by: IB Advertising
- Toyota Tundra How to Replace Headlights and Fog Lights<br>Step by step instructions for do-it-yourself repairs.
Changing driving light housing Driver side
Hello, newb here, I recently had a rock come through my drivers side driving light housing and smash it pretty good. Luckily no other paint damage. I've gotten a replacement, but have gotten stuck at removing the headlight and driving light assemblies. Anybody have any tips, tricks or suggestions?
Thanks
Jacob
Thanks
Jacob
I have a Tundra, but I am pretty sure it's the same way to get the headlight off, I'll look exactly at the manual tonight and get back to you, more than likely you have to remove the corner light to access a screw that may otherwise be hidden, and there are probably three other screws somewhere, like two on the top and one on the bottom with a a side screw somewhere.
Okay according to the Tundra manual, there are a total of four screws, you must remove the corner light to access the top screw and bottom screw on the outside. After you get those two, apparently there are two other screws in the bottom inside of the headlight (obviously, not to insult your intelligence, I would hope that you have the hood open while doing this). After you get them, if you don't see any clips holding the headlight in, you should be able to pull it out. good luck
that way we can better help you.
