99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 03:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Lighting Guides
Print Wikipost
Changing driving light housing Driver side
Old Mar 27, 2004 | 04:53 PM
jake11566's Avatar
Hello, newb here, I recently had a rock come through my drivers side driving light housing and smash it pretty good. Luckily no other paint damage. I've gotten a replacement, but have gotten stuck at removing the headlight and driving light assemblies. Anybody have any tips, tricks or suggestions?
Thanks
Jacob
Old Mar 28, 2004 | 03:33 PM
Mohamed's Avatar
Uh....it might help to notate what model truck (Tundra or T100) you have and year that way we can better help you.
Old Mar 29, 2004 | 08:28 AM
jake11566's Avatar
:pat: Thought I did, it's a 03 Sequoia
Old Mar 29, 2004 | 11:50 AM
Mohamed's Avatar
I have a Tundra, but I am pretty sure it's the same way to get the headlight off, I'll look exactly at the manual tonight and get back to you, more than likely you have to remove the corner light to access a screw that may otherwise be hidden, and there are probably three other screws somewhere, like two on the top and one on the bottom with a a side screw somewhere.
Old Mar 29, 2004 | 06:54 PM
Mohamed's Avatar
Okay according to the Tundra manual, there are a total of four screws, you must remove the corner light to access the top screw and bottom screw on the outside. After you get those two, apparently there are two other screws in the bottom inside of the headlight (obviously, not to insult your intelligence, I would hope that you have the hood open while doing this). After you get them, if you don't see any clips holding the headlight in, you should be able to pull it out. good luck
gillesdetrail
Nov 19, 2019 12:56 PM
miceal383
Jun 29, 2015 12:27 AM
