99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Broken cam gear alinment pins
Old Dec 18, 2012 | 10:01 AM
FUNrunner87's Avatar
I am working on a 4.7L v8 from a tundra. Both cam bolts where broken off, but cam out with my fingers. Now, I am trying to figure out the best way to remove the alinment pins. I am not sure how this happend, I am just trying to salvage the engine. Valve train is other wise fine.
Right side Cam bolt
Left side: (both sides look like this now)
I assume that the pins are hardened steel?
Old Dec 18, 2012 | 01:51 PM
MudHippy's Avatar
The best way I can think of would be to use a stud welder. The kind used to pull dents in body panels. Weld a stud on 'em and use the slide hammer tool that comes with the gun to pull 'em on out.
Second best way would be to drill 'em out with a cobalt steel drill bit. Unless they start spinning...then you're screwed there. Pardon the pun.
Old Dec 18, 2012 | 03:36 PM
Worked on one cam for about 2 hours tonight and wile I could drill into it, I couldnt get it to come free. The hole is all jacked up now, and the cam is already in the trash. Ill find a used set on car-part.com.
Old Dec 18, 2012 | 04:28 PM
rworegon's Avatar
Ugh..... Is the 4.7 an interference engine? If so, I'd be a bit worried seeing both those cam bolts and pins sheared that there is internal damage someplace.
Old Dec 18, 2012 | 04:51 PM
yes, the 4.7L is an interference engine. Took the pass head off, valve train looks fine, and there are no marks on the pistons. I plan to pull the drive side head off tomorrow to make sure everything is fine on that side too.
Old Jan 15, 2013 | 09:15 AM
dyogim's Avatar
If you are still looking for a set of cams, I can pull mine and sell them to you. I'm in the process of swapping out my motor with another one. So, the old one will more than likely be parted out....
I also have a complete 2UZ-FE block that only has 5000 miles on it I'm trying to get rid of. Otherwise, I may keep it and build it up later. Send me a PM or email me at dyogim at gmail dot com.
Old Jan 15, 2013 | 09:38 AM
Hey, I spoke to you on TTORA, my user name over there is Yotaoffroad. I actually found a complete set of cams on Ebay and bought them, just find out I needed to replace the heads too. I found a set of heads and they came with cams... So now I have 4 sets of left side cams, and 3 sets of right side..
so if anyone wants a set of cams... PM me. Ill cut you a SWEET deal!
Old Jan 15, 2013 | 09:58 AM
dyogim's Avatar
LOL!!! I thought it was since, the locations were the same but, wasn't sure. You can use those extra cams to build the block I have. Still working on those misc. parts for you. Will let you know as soon as possible.
Old Jan 15, 2013 | 10:23 AM
Hahahaha!!!! I have wasted.. I mean spent enough money on this dud of an engine already.
Just let me know once you have figured out what parts you are going to sell. I use TTORA more than here, I got a notification in my email to check this thread.
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
keithporter83
Jul 18, 2015 12:37 PM
msane99
Jul 17, 2015 10:13 AM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
