99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Bank one?
Old Feb 20, 2004 | 11:47 PM
clodhopper's Avatar
Bank one?
I know this is a dumb question, but which side of the Tundra V8 is bank one?
My first attempt at replacing a O2 sensor.
Code check says, "heated O2 malfunction" or something like that.
And then, "bank one, first sensor" I think it was.
And where is this located?
Thanks. :wtf:
Old Feb 21, 2004 | 11:46 AM
clodhopper's Avatar
Originally Posted by midiwall
The bank one sensor is the one in front of the catalytic converter.
Have fun!
Mark
Thanks Mark, but which side of the engine is bank one? Is it the drivers side?
Old Feb 21, 2004 | 11:58 AM
Mohamed's Avatar
Actually according ot my manual, bank 1 is just underneath the exhaust manifolds, both driver's and passenger side are listed as bank 1.
Old Feb 28, 2004 | 08:49 PM
DarylD's Avatar
Hey Mark ,watcha doin over here? The V8 Tundra has 4 O2 sensors . Bank 1 is drivers side , I think ? I can let you know for sure on monday. Check with the dealer it may still be covered .
Old Feb 28, 2004 | 10:09 PM
midiwall's Avatar
oops... thank goodness you've got my back.
I'll delete my other posts to avoid confusion. I wasn't paying attention and figured it was like the 4Runner. I didn't notice what forum we were in.
(going back to my 4Runner cave now)
Old Feb 29, 2004 | 03:24 AM
toy283's Avatar
If it is numbered like every other V type engine, it is the bank that is slightly forward of the other one. Since pistons on V type engines can't be directly opposite, they are shifted slightly (about the thickness of a connecting rod to be exact). The first bak is the one with the furthest forward cylinder which, ironically, is usually #1. Go figure.
Old Feb 29, 2004 | 06:51 AM
MTL_4runner's Avatar
Thanks. :wtf:
Bank 1 refers to a particular side of the engine and the OBD code should have also spelled out a sensor as well (like bank 1, sensor 2). The sensor number refers to the forward or rear sensor (sensor 1 = forward, sensor 2 = rear or further down the exhaust). Bank 1 on any car with multiple banks (ie any V type motor) is usally on the right side as you face the engine or whatever side plug #1 is (also usually drivers side of the truck). Some may vary but hat is what is typical anyway.
If you have a V8 the sensor should be very close to the exhaust manifolds.
These are aftermarket but the stock should be similar too:
crammit442
7
Nov 29, 2017 12:30 PM
Draven023
Sep 26, 2015 12:41 PM
djohnson13
Sep 4, 2015 12:35 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
Tacoma Dude
Feb 29, 2004 10:04 AM
