99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
back space?
Old May 16, 2003 | 04:28 PM
Kookadala's Avatar
back space?
I am planning on getting some 35s sometime this year and was thinking of moving up to 16-inch wheels so theres not so much tire sidewall showing. However, it seems like the wheel increase leads to an increase in back space. 15s give 3.75-inch while 16s give 4 or more. How much can you have before the steering gear rips the back sidewall of the tire open?:pat:
Old Jun 16, 2003 | 11:14 AM
97 T-100's Avatar
my T-100 came with 16 inch wheels( which i changed to 15 inch because tires are cheaper and original rims sucked), but they were the stock ones. there will be a chance that any rim you put on will have a different offset. i would stick with a rim with stock, or near stock backspacing if you don't have a lift. if you go too wide it will rub the outside of the fenders and too far in you may have the same problem or rubbing on the inside. you would also loose some stability, and your truck would look funny.
Poncho0206
Jul 10, 2015 06:21 PM
87blyota
Jul 10, 2015 04:31 AM
Kluch8651
Jul 9, 2015 10:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
elwood73
Jul 5, 2015 07:07 AM
