99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 01:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Print Wikipost
2000 Tundra - Heater problems
Old Nov 17, 2004 | 07:19 AM
Daryl's Avatar
My heater would not reach a "hot" temperature when I tried it the first time this fall. Assuming it was the thermostat, I replaced it but that didn't help. The engine temp is running normal. Any ideas?
Old Nov 17, 2004 | 07:24 AM
Rivalred's Avatar
Is there any air that is coming out of the vents?
Might have a clogged or bad heater core if cold air is just coming out....
Old Nov 17, 2004 | 07:40 AM
Daryl's Avatar
The flow is fine. The temp is warm.
Old Nov 17, 2004 | 07:47 AM
Rivalred's Avatar
So then the flow is warm, but not what it was then?
Old Nov 17, 2004 | 08:10 AM
Daryl's Avatar
Yes, the flow is barely warm. I thought about the clog possibility, but the fluid I drained when replacing the thermostat (180 degree) was very clean.
Old Nov 17, 2004 | 08:16 AM
Rivalred's Avatar
If there a cable at all that could need adjusting?
Family members Matrix A/C was not cool enough and it was just a cable adjustment.
Old Nov 17, 2004 | 08:36 AM
Daryl's Avatar
The cable for the temp control? I can hear the vent change, but perhaps it's not moving far enough.
Old Nov 18, 2004 | 06:56 AM
Sumo99's Avatar
I believe there is a TSB for this. Let me see if I can find it.
Old Nov 18, 2004 | 08:15 AM
Sumo99's Avatar
I was wrong. I was thinking of the TSB for the air conditioning system.
Did you check the heater valve? Does it move when you turn the temp. control dial? Did you check the heater control assembly? It seems like many of the heat problems come from one of the control cables coming uncliped, especially behind the glovebox.
Old Dec 1, 2004 | 06:09 AM
Daryl's Avatar
I can tell that something is moving when I operate the temp control. I'll try to examine the heater valve movement (if I can find it). I removed the glovebox...and it's tight back there.
the1998sr5
15
Jul 14, 2020 08:35 PM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
Suprarossa
Jul 6, 2015 05:21 AM
