99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
'03 Sequoia automatic door lock
Old Mar 16, 2003 | 10:12 PM
bufflee's Avatar
Question '03 Sequoia automatic door lock
I have tried to change the automatic door lock feature from Mode 1 (default from factory) to Mode 2, which is the doors lock after reaching 12 mph, but have had no luck. I have followed all the steps as outlined in the owner's manual to do this.
Anybody out there has had success changing these modes?
Old Mar 20, 2003 | 05:57 AM
nhparrot's Avatar
The following steps to program the Sequoia door looks to automatically lock at 12mph, works for 2002 Sequoia's. However for the 2001 models the dealer must perform the programming using a hand-held tester plugged into the OBDII port. This function is the Auto Door Locking function.
1. Set the parking brake, close all doors and turn the ignition to the ON position.
2. Shift the selector lever from the "P" to the "N" position.
3. Press the driver side power door lock switch on the "front side" for about 5 seconds,
within 10 seconds after the ignition switch is turned to the "ON" position.
4. the doors will be locked and unlocked to indicate that the function is set.
To cancel the setting, repeat the process above.
westonian18
May 1, 2020 06:38 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
shisha1999
Sep 20, 2015 11:44 AM
moonpie
Jul 31, 2015 11:58 PM
defrag4
Jul 31, 2015 10:50 AM
