99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 02:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Print Wikipost
01 Tundra 5vzfe Running lean
Old Mar 29, 2012 | 04:44 PM
jbtvt's Avatar
Originally Posted by 4Voigt's
the way it sounds it is almost like fuel cut. You may try a new crank sensor. the only reason i say this is that i've seen it twice. once on a 3rd gen runner and once on a taco. both 5vz. the sensor doesn't seem to pick right as the rpms rise and it starts cutting fuel. just a thought.
That's funny. I was just reading about that 3.4 issue on a page dedicated to those tricky to solve issues, as I debate whether to pull my VSS tomorrow.
http://www.motor.com/article.asp?article_ID=271
Old Mar 30, 2012 | 02:27 PM
rapt0r's Avatar
Well, first off I wanted to say I appreciate all the advice and help, it got me further in fixing it. I got it to stop knocking so badly by cleaning the Idle air control (green block right under throttle body) it was carboned in a fixed position. I cleaned it really well and got it to no longer ping and knock, but still had the cutting out and nose over from 3/4 throttle up. I had someone make me an offer on it that I couldn't refuse, and I have sold it...which I'm sad to see her go, but after 10 years of never letting me down and 193K miles, I'm going to let someone else bitch at her.... LOL. I really think it was down to I needed a new a/f sensor and a crank or cam position sensor.
I'm still going to stay on here, at some point in the future I may get me an older Yota... one of the smaller p/u's... any recommendations on a good long running direction to take on that?
Old Mar 30, 2012 | 05:09 PM
jbtvt's Avatar
I like the 3.0 now that (or maybe because) I've gotten the hang of working on it, but you can't go wrong with Yota.
Old Mar 30, 2012 | 05:41 PM
Kiroshu's Avatar
The Crank Postion sensor(CKP) is part of the igntion system. Normaly does not cut fuel as apose to "cutting spark." However If there is a fault with the CKP then it will cut spark slightly and when the computer sees "weak or improper burn time" then it cuts fuel.
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
Doug4320
Mar 24, 2018 10:11 PM
jon.r
Jul 11, 2015 03:34 PM
Suprarossa
Jul 6, 2015 05:21 AM
