99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
'00 2uz-fe p0171
Old Jul 27, 2012 | 08:33 AM
toyota4x4907's Avatar
'00 2uz-fe p0171
2000 Tundra 2UZ-FE (v8), 129K miles. When i bought it, the CEL was on and was displaying P0171 which is bank 1 lean. I cleared it, and it was gone for nearly 5 months. It came back on one day after some particularly hard driving, cleared it, it stayed off until this last May when the temperature got above 70F. Now, whenever the temp gets above 70-75F, that same code shows up. Not ALL THE TIME. I can clear the code and it will stay off for a day or two. Once, though, I did get both P0171 and P0172, which is both banks lean.
Also, when it is above 70F, it takes two tries to get it to start. I will crank it for about 5 seconds, stop, then crank it again and it will start up. Then about every 4-5 times this happens, it sputters and barely starts. It does all this after sitting in the 70F+ temp for 3-4 hours or more.
Any help?
Old Jul 30, 2012 | 07:24 AM
Bump. Any ideas?
Old Jul 30, 2012 | 08:50 AM
250000_yota's Avatar
Try cleaning the mass air flow sensor, and check for vacuum leaks and fuel pressure. The fuel pressure issue might be causing the two try start.
(make sure to use actual mass air flow cleaner. Anything else might be too tough on the sensor)
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
catusphile
10
Jul 27, 2020 02:38 PM
mreagen
Engine Swaps
Aug 4, 2015 10:54 PM
