NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics
Old Nov 16, 2021 | 08:10 AM
Diode Dynamics's Avatar
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-vf0aaq7.jpg
Diode Dynamics is excited to introduce ourUniversal Stage Series Flush Mount Reverse Light Kit!
There's plenty of ways to add light behind your vehicle, but the new Universal Stage Series Reverse Light Kitstands out with innovations in both function and ease of use. This kit allows you to mount two flush mount SSC1 or SSC2 LED pods in your rear bumper, adding a high-power reverse light, along with a red accent light. With the included wiring harness, this kit connects to your vehicle's wiring for simple, everyday operation.
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-pcnyzzd.jpg
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-2vrtdrd.jpg
While other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series LED pods serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series Pod is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-gxqbxec.jpg
Simple connections. The included wiring harness allows you to connect this kit to your vehicle's wiring for simple, everyday operation. The kit operates as an additional red accent light, with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. The included toggle switch allows you to override the vehicle signals and turn on the main beam anytime.
Each kit will include:
Two (2) SSC1 or SSC2 Flush Mount LED Pods
One (1) Universal Reverse Light Wiring Harness
Two (2) Flush Frame Gaskets
Ten (10) Zip Ties
Two (2) T-Taps
Mounting hardware and drilling template
Functional Patterns. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod, and a 60x60 degree spread on the SSC2 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-fjq0trb.jpg
Backlight Functionality. The Stage Series LED pods included with this kit feature a distinctive backlight in a vibrant red color which functions as an additional accent light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power. Click the Specifications tab to see more information!
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-7xjmj3m.jpg
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Old Nov 19, 2021 | 08:29 AM
FormerVendor
SS3 Backlit is NOW AVAILABLE for pre-order!
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-vyxkxrm.jpg
The highest-intensity pod on the market is now available with an integrated amber backlight feature.
Click HERE to shop vehicle specific SS3 LED fog light kits!
Just a reminder, feel free to send us a PM for a free US shipping code.
John C.
Diode Dynamics
Old Jan 12, 2022 | 08:58 AM
FormerVendor
FREE CALENDAR ALERT!
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-ooqdoec.jpg
For a limited time with every $300 purchase, we're throwing in our new 2022 Diode Calendar!
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-fxlceq8.jpg
Plus, all forum US forum members are eligable for a free shipping promo code. Just PM us!
Old Feb 4, 2022 | 10:43 AM
FormerVendor
Did you know?
We offer our Universal Reverse Light Wiring Harness separately to pair with any of our Backlit Stage Series LED pods!
There have been many customers custom mounting our standard (non-flush) pods to their vehicle using our universal mounting brackets and hardware to factory mounting locations!
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-afd6vrt.jpg
Please, feel free to let us know if you have any questions!
John C.
Diode Dynamics
Old Apr 13, 2022 | 08:40 AM
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-nex2ulw.jpg
For the month of April, we're throwing in a FREE Diode Flag Tee when you spend $300 or more.
Click HERE to shop your ride!
Old May 26, 2022 | 12:04 PM
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-ei69vni.jpg
Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
Get 15% off all LED lighting upgrades with code "USA22" during checkout!
Plus, all orders over $300, will receive FREE shipping.
Click HERE to shop Diode Dynamics LED Lighting products!
Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
Old Jun 3, 2022 | 12:42 PM
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-0m1vhyp.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades!
Coupon Code: USA22
Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
Note: Items on pre-order are exempt from the sale.
Old Sep 6, 2022 | 11:08 AM
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-emnntur.png
The clock is ticking!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
Old Mar 6, 2023 | 08:09 AM
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-ilhqa2p.png
Our Spring Sale is LIVE! 🚨 Visit our website to SAVE!
➡ Up to 15% OFF All Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
No coupon code is required.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
Old Mar 10, 2023 | 11:29 AM
FormerVendor
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-jwrwzye.png
⌛THE CLOCK IS TICKING... ⌛
NOW
is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
Up to 15% OFF LED Lighting Upgrades
CLICK HERE TO SHOP NOW
NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics-qd4beir.jpg
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Old May 9, 2023 | 10:42 AM
FormerVendor
Old May 25, 2023 | 11:47 AM
FormerVendor
🚨 Our Memorial Day Sale is LIVE!!! 🚨[/CENTER]
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
