💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics
Old Jun 9, 2021 | 10:16 AM
Diode Dynamics's Avatar
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-pxnuztw.jpg
Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2016-2021 Toyota Tacoma!
The Stage Series LED Ditch Light Kit for the 2016-2021 Toyota Tacoma allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-l3ofbdg.jpg
Built to last. The brackets in this kit are constructed out of thick-gauge stainless steel. Unlike other options made out of mild steel, these brackets are full stainless steel and won't corrode over time. With their thick-gauge construction, you also won't experience any vibration or bouncing while driving.
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-jaait2c.jpg
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-w8dqowb.jpg
While other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS3 and SSC2 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series Pod is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Click HERE to check out the Stage Series LED Ditch Light Kit for 2016-2021 Toyota Tacoma!
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-5ahomif.jpg
SSC2 Pro LED Pod - Combo Beam Pattern
Functional output. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
  • Combo combines both the Driving and Flood optics. The SS3 shines light downrange in a focused, rectangular 65x25 degree pattern, while the SSC2 shines light downrange in a 40x20 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-fcjxior.jpg
White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road. We also offer replacement lenses that allow you to change the color or optic of your SS3 or SSC2 Pods.
Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power!
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-ragjzww.jpg
Backlight Functionality. All SSC2 Ditch Light Kits include a distinctive Amber backlight feature. The SSC2's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-x8syknp.jpg
Bolt-On Installation: The thick-gauge stainless steel brackets in this kit were CAD-designed to utilize existing mounting points for a bolt-on installation - there is no cutting or drilling required!
Each kit will include:
  • Two (2) SS3 or SSC2 Standard LED Pods
  • Two (2) Ditch light brackets
  • Two (2) SS3 or SSC2 Mounting brackets
  • One (1) Heavy-duty dual output wiring harness
  • Mounting hardware
  • Mounting guide
See how to install our Stage Series LED Ditch Light Kit for 2016-2021 Toyota Tacoma below!
Customizable: If you’re looking to change the output color, add a layer of protection, or simply add some extra style to your SS3 LED pods, our snap-on covers are a great option. Like our scratch-resistant SS3 lenses themselves, the SS3 Pod Covers are made with a strong polycarbonate plastic, to protect against whatever the road throws your way.
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-zi6vdgi.jpg
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
Old Aug 13, 2021 | 07:58 AM
FormerVendor
Check out this incredible shot from Ralph Schneider rocking our SS3 Pro LED ditch light kit in 6000K cool white with our driving optic!
Remember, all forum members are eligible for a free US shipping code. Just PM us!
John C.
Diode Dynamics
Old Aug 20, 2021 | 08:36 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-m65ygmz.jpg
Did you know our SSC1 pods can be mounted to the side of our SS3s? All you need is a universal SSC2 bracket!
Click here to shop SSC1 LED Pods!
Click here to shop SSC2 universal mounting bracket!
Remember, all forum members are eligible for free US shipping. Just send us a PM for the code!
John C.
Diode Dynamics
Old Sep 17, 2021 | 10:48 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-zm0cybx.jpg
Check out this incredible shot from Garrick Vanderwal rocking our SS3 Max LED pods as ditch lights on his Tacoma!
Remember, all forum members are eligible for a free US shipping code. Just DM us!
John C.
Diode Dynamics
Old Oct 6, 2021 | 12:46 PM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-lttzqms.jpg
Interested in learning more about our patent-pending Total Internal Reflection (TIR) optics? Click here!
Old May 10, 2022 | 10:42 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-3b3fjdg.jpg
We're including free covers with every backlit Stage Series LED pod purchased for a limited time!
This promotion includes covers with ditch light kit orders and crosslink lightbars.
Which pods included our backlight feature?
Have any questions or concerns? We're here to help.
Click HERE to view our backlit Stage Series LED Pods!
Don't forget, US forum members are eligible for a free shipping code. Just direct message us!
Old Jun 3, 2022 | 12:45 PM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-0m1vhyp.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades!
Coupon Code: USA22
Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
Note: Items on pre-order are exempt from the sale.
Old Jul 5, 2022 | 01:53 PM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-zb8vcbd.jpg
THE CLOCK IS TICKING!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Old Jul 8, 2022 | 11:29 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-v8uncsm.jpg
ALERT: LAST CHANCE TO SAVE 15% OFF!!!
COUPON CODE:
JULY4
Plus, all orders over $300 will receive free US shipping!
Don’t wait...this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2021. Cannot be combined with other coupon codes.
Old Aug 12, 2022 | 07:58 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-n37szrg.jpg
Installer // @prolightz
Old Nov 21, 2022 | 07:35 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-c8ut5ea.jpg
Our Black Friday Sale is LIVE! 🚨 Visit the website for our BIGGEST savings ever!
20% OFF Sitewide
30% OFF Stage Series Single-Row Lightbars
15% OFF Elite Series Headlights
➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
No coupon code is required.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Old Nov 29, 2022 | 08:42 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-z4oe9qr.jpg
Our BIGGEST and LAST sale of the year ends TODAY 11/29 at 11:59 pm CST!
20% OFF Sitewide
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
Hitch Mount LED Pods (Includes free US shipping)
CLICK HERE TO SHOP!
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Old Mar 6, 2023 | 09:03 AM
FormerVendor
💥NEW!💥 Stage Series Ditch Light Kit for 2016-2021 Toyota Tacoma! | Diode Dynamics-njmwsdb.png
Our Spring Sale is LIVE! 🚨 Visit our website to SAVE!
➡ Up to 15% OFF All Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
Click HERE to shop your ride!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
PureTacoma_Tundra
PureTacoma_Tundra
Dec 5, 2020 07:33 AM
PureTacoma_Tundra
PureTacoma_Tundra
Nov 25, 2020 12:03 PM
