💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics
Old Aug 12, 2021 | 07:29 AM
Diode Dynamics's Avatar
FormerVendor
Lightbulb 💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-kdyxpeh.jpg
Diode Dynamics is excited to introduce our SS3 Fog Light Kit for the 2006-2012 Toyota RAV4!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-2npngnd.jpg
SS3 Max LED Fog Light Kit - 3000K Selective Yellow
Instagram User: @LightWerkz
Our SS3 LED Fog Light Kits are now available for the 2006-2012 Toyota RAV4! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-nnosjll.jpg
SS3 Max LED Fog Light Kit - 6000K Cool White
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic in the SS3 collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-3kmettj.jpg
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
Functional Output: All SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. Making it a perfect option for your factory fog location! We offer these kits in two SAE-compliant optics:
  • Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
  • Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
*When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-e5kvd1y.jpg
SS3 Sport LED Fog Light Kit - 3000K Selective Yellow - SAE Fog Optic
White or Yellow: Our SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-p7j8rw7.jpg
Sport/Pro/Max: Stage Series LED Pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The sport model uses high-intensity LEDs and is the best bang for your buck you’ll find. The Pro steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, both for high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2006-2012 Toyota RAV4 includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
Each kit will include:
  • Two (2) 3” Angled SS3 LED Pods
  • Two (2) H11 DT Adapters
  • Mounting brackets and hardware
Note: This kit is a replacement for OEM fog lamps. If your vehicle does not have fog lamps, additional hardware and wiring may be needed for installation.
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-wthnsh9.jpg
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
Old Sep 2, 2021 | 07:20 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-ni4rv4v.jpg
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our SS3 LED fog light kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Cannot be combined with other coupon codes.
*Sale excludes preorders.*
Old Sep 10, 2021 | 06:16 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-xm8dzdk.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Fog Light Kits, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Old Oct 6, 2021 | 12:46 PM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-lttzqms.jpg
Interested in learning more about our patent-pending Total Internal Reflection (TIR) optics? Click here!
Old Oct 14, 2021 | 12:04 PM
FormerVendor
Our popular SS3 LED Pods are back in stock and ready to ship!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-iaand6g.jpg
Plus, you can send us a direct message for free USPS standard economy shipping on all US orders!
Old Nov 11, 2021 | 01:10 PM
FormerVendor
Have you guys seen the Diode Dynamics product launch from SEMA 2021?
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-xkzvjs7.jpg
Due to high demand, SS3 LED pods will soon include a backlight feature!
6:03 - SS3 Backlit
If you have any questions, I'll be glad to help!
John C.
Diode Dynamics
Old Nov 19, 2021 | 08:35 AM
FormerVendor
SS3 Backlit is NOW AVAILABLE for pre-order!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-vyxkxrm.jpg
The highest-intensity pod on the market is now available with an integrated amber backlight feature.
Click HERE to shop vehicle specific SS3 LED fog light kits!
Just a reminder, feel free to send us a PM for a free US shipping code.
John C.
Diode Dynamics
Old Nov 22, 2021 | 10:35 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-rkofoj9.jpg
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our new Backlit SS3 LED fog light kits, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/30/2021.
Old Nov 30, 2021 | 07:34 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-tqajgix.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our new Backlit SS3 LED fog light kits, by entering coupon code "BF21" at checkout! Plus, get a free Diode Dynamics Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Old Jan 12, 2022 | 08:48 AM
FormerVendor
FREE CALENDAR ALERT!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-ooqdoec.jpg
For a limited time with every $300 purchase, we're throwing in our new 2022 Diode Calendar!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-fxlceq8.jpg
Plus, all forum US forum members are eligable for a free shipping promo code. Just PM us!
Old Jan 19, 2022 | 08:06 AM
FormerVendor
Our production team has just finished up testing our SS3 backlit LED fog light kits!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-vsqhwdl.jpg
Pre-orders are NOW shipping.
If you have any questions, please feel free to let our team know!
Old Jan 25, 2022 | 07:41 AM
FormerVendor
"Are your SS3 LED pods are able to melt ice and snow built up?"
Yes, our SS3 Pro and SS3 Max power levels are able to melt snow and ice build-up!
Unfortunately, our SS3 Sport doesn't produce enough heat to melt snow and ice build-up.
Have questions regarding our Stage Series LED pods? Just let us know, we'll be happy to help!
Old Feb 16, 2022 | 11:21 AM
FormerVendor
Did you know?
Our team here at Diode Dynamics is an energetic group of over 80 people, who work hard to make quality lighting, with the best service possible in St.Louis, Missouri.
We take pride in our quality products, our customer-focused service, and our work in going "against the grain" to manufacture products here in the USA!
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-wzoiqc5.jpg
John C.
Diode Dynamics
Old Mar 22, 2022 | 10:35 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-ozxa2eh.jpg
Diode Dynamics’ 15% OFF flash sale is going on NOW!
Get 15% off all LED lighting upgrades with code “FLASH” at checkout.
This sale ends tonight, 3/22 at midnight (CST)!
CLICK HERE TO SHOP!
Old Apr 13, 2022 | 08:47 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-nex2ulw.jpg
For the month of April, we're throwing in a FREE Diode Flag Tee when you spend $300 or more.
Click HERE to shop your ride!
Old Jun 3, 2022 | 12:59 PM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-0m1vhyp.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades!
Coupon Code: USA22
Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
Note: Items on pre-order are exempt from the sale.
Old Jul 5, 2022 | 11:52 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-67ue5bb.jpg
THE CLOCK IS TICKING!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Old Sep 2, 2022 | 08:33 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-atwnucw.png
Our Labor Day Sale starts NOW! Today through Friday, 9/9/2022, save 15% on all LED upgrades by entering coupon code "LABOR22" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
Old Nov 29, 2022 | 09:18 AM
FormerVendor
💥NEW!💥 SS3 Fog Light Kit for the 2006-2012 Toyota RAV4! | Diode Dynamics-k5lzity.jpg
Our BIGGEST and LAST sale of the year ends TODAY 11/29 at 11:59 pm CST!
20% OFF Sitewide
30% OFF Stage Series Single-Row Lightbars
15% OFF Elite Series Headlights
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
Hitch Mount LED Pods (Includes free US shipping)
No coupon code is required.
CLICK HERE TO SHOP!
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
