putting 1uzfe in a 91 land cruiser, what is needed.
can i do a 5 speed from a later model like 98 ls400 or other type Lexus ?[auto] swap or should i do a 4 speed auto . I have done the 91 pick up 1uzfe with inch worm adapt and marlin 23 spline input for t-case.. will there be oil pan issues and what adapter do i need for adapting the trans to t-case ? The land cruises has a auto and i am putting in a auto, Need wisdom before doing,
I don't have direct experience with the LC or the 5 speed trans, but logic in my mind would be you'd need the ECU that controls the 5 speed, and it will need to be able to run the v8 engine. If the 5 speed trans is from a UZ series engine, it should physically fit the engine.
arlindsay1992
08-19-2018 02:20 PM
diableri
05-05-2013 08:36 PM
Mark in Az
13
09-29-2006 01:43 PM
