Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
Missing starter ground wire for 92 FJ80 3FE
Old Dec 16, 2012 | 12:43 PM
gr8drives's Avatar
While replacing the starter with an OEM reman, no ground wire was found on the bottom mount bolt as depicted in the FSM. Instead, there is what appears to be a ground near the top starter mount post (see picture). This possible ground, however, only appears to attach to a plastic clamp that rotates freely on the underlying sheathed cable bundle -- it has no actual further wire/connection to standard grounding points. Have no history from PO.
Has anyone seen this? Where should the ground wire be located?
Attached Thumbnails Missing starter ground wire for 92 FJ80 3FE-92-fj80-3fe-starter-mount-location-2.jpg
Old Dec 18, 2012 | 02:48 PM
rokblok's Avatar
That's not a ground, as far as I can see. That is a support for the wiring harness. The starter can be grounded through the engine, and a separate ground wire can be put elsewhere. Starter may have been replaced in the past and someone moved the ground wire to another bolt on the engine or head maybe, or it can even come from the factory attached to a different place.
Sleaker
Aug 26, 2020 06:03 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Doug4320
Mar 24, 2018 10:11 PM
montanatruck
Feb 26, 2017 07:07 AM
colinmil
Jul 6, 2015 04:03 PM
