glow plugs
First off do you know what the function of glow plugs is? All they do is heat up the air in the cylinder or head when you first turn your key before you engage the starter. After that they are not used. The only reason you would need to replace them is if they no longer work and you live in a cold climate where they're needed to get it started. As to replacing them if you really do need to they probably have an o-ring so that the high compression will not escape past them and im sure there is a torque, look for an online fsm for your truck or motor.
Blamalam
Mar 12, 2022 07:34 AM
