Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
glow plugs
Old Mar 26, 2008 | 10:47 AM
j's Avatar
j
glow plugs
want to replace my glow plugs on 83 landcruiser bj60 3b motor. have no clue where to start. any help.
Old Mar 26, 2008 | 10:49 AM
zlathim's Avatar
Check them with an ohm meter first. I'm not sure what the value should be for your rig, but an open circuit = bad glow plug. Put one lead on the terminal of the GP and the other should be grounded to the block.
Old Apr 5, 2008 | 11:32 AM
j's Avatar
j
replacing them today. is it as easy as unscrewing the old ones and screwing the new ones in? do i need to prime the cylinders? thanks
Old Apr 5, 2008 | 12:16 PM
Jeenyus04's Avatar
First off do you know what the function of glow plugs is? All they do is heat up the air in the cylinder or head when you first turn your key before you engage the starter. After that they are not used. The only reason you would need to replace them is if they no longer work and you live in a cold climate where they're needed to get it started. As to replacing them if you really do need to they probably have an o-ring so that the high compression will not escape past them and im sure there is a torque, look for an online fsm for your truck or motor.
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kcaudill
Jul 20, 2015 12:06 PM
msane99
Jul 17, 2015 10:13 AM
