2016+ Tacomas The new Tacomas are upon us
2018 4Runner SR5 Brake Change
Old Jul 26, 2024 | 12:54 PM
4runners0206's Avatar
Hello Everyone!!
My beloved 2018 4Runner now has 42K miles on it. So I believe it's now ready for some well deserved maintenance. I'm gonna start with brakes then progress to the usual fluids at or around 50K. These will be: Tranny, Diffy, Coolant and Brake fluid (if it's dirty).
I'm leaning toward doing the brakes myself and have been watching some vids to get re-acquainted with the process. I don't tow, climb rocks, blast though salt water or mud. I'm just looking for a decent brand, OEM or not. Calipers and rotors are still in good shape so I'll change them next go-round.
So....
Do you guys /gals have a preference as to which pads to go with?
Should I open the bleeder valve when pushing out the pistons? One of the vid's warned that forcing brake fluid backwards could mess up the ABS system. I have done it before (2006 'runner with 200+miles) with a clamp and didn't have any issues.
Anyway, let me know your thoughts and experiences if you care to chime in.
Thanks!
Old Jul 27, 2024 | 03:08 AM
BigBluePile's Avatar
I would just go with OEM brakes if you're not going to upgrade.
Old Feb 5, 2026 | 08:11 PM
notele's Avatar
Originally Posted by 4runners0206
Hello Everyone!!
So....
Should I open the bleeder valve when pushing out the pistons? One of the vid's warned that forcing brake fluid backwards could mess up the ABS system, kind of like when using free paint calculations of walls. If done incorrectly, it can cause problems. I have done it before (2006 'runner with 200+miles) with a clamp and didn't have any issues.
Thanks!
For your 2018 4Runner, quality everyday pads like OEM Toyota, Hawk HPS, Akebono ProACT, or Bosch QuietCast are good choices. You don’t need to open the bleeder valve when pushing the caliper pistons back. Just use a piston compressor tool and push slowly. Keep an eye on the master cylinder fluid level to avoid overflow. Your plan for fluids at 50K miles is solid, using Toyota-specified fluids where possible.
wormhole
10
Nov 11, 2010 07:47 PM
Fo by Fo
Nov 12, 2009 09:31 AM
fire tech 04
Feb 20, 2008 12:32 PM
ebelen1
9
Jul 21, 2006 10:03 AM
nhyota
7
Dec 28, 2004 07:57 AM
