Nitro Gear and Axle Chromoly FF Rear Axles for LandCruiser and More!
Old Aug 8, 2013 | 06:38 PM
justdifferentials's Avatar
Nitro Gear & Axle Chromoly Full Float Rear Axle Shafts for Toyota LandCruiser & Custom Applications! Now available!
Toyota Trucks & Landcruisers are well known for their strength & reliability all over the world. Out of the box they feature some pretty great drivetrain, but they do have their limits. The factory 30 spline full-floater axle shafts are not built to withstand the added stress of larger tires and heavy offroad use. Nitro Gear & Axle has addressed this by offering a range of Heavy Duty Chromoly Rear Full Float Axles. The only Full Float rearends offered by Toyota in the US were in Dually Pickups, and FZJ80 Land Cruiser, however Full float axles were much more popular worldwide in all models of Landcruisers and are commonly used as an upgrade for US models and otherwise.
Chromoly Full Float Rear Axle Shafts for Toyota LandCruiser & More:
-Made in USA
-High strength Chromoly Material featuring State of the art machining, heat-treating and polishing processes for uniformity and ultimate in strength.
-Wide application range suiting most Toyota pickups, 4runners & Land Cruisers as well as custom applications
P/Ns:
AX TFF-FJ40 TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS 40 45 REAR
AX TFF-FJ60 TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FJ60/HJ60 /62REAR
AX TFF-FJ80 TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FZJ80, HDJ80 REAR
AX TFF30-L TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFT CUT TO LENGTH 30.5”-38.25”
AX TFF30-R TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFT CUT TO LENGTH 21.5”-28.9”
-TOYOTA F/F 30 SPL CTL AXLES ELOCKER OK!
-ENOUGH SPLINE TO WORK FOR 40, 60, 80 SERIES LC ETC CTL (Cut-to-length).
This means the axles come with extra-long splines to accommodate numerous applications.
Long splines also allow use of OEM Cable / Electric Locker. Simply chop to desired length. This makes them easy to stock for the average 4x4 shop, as 1 pair of shafts fits many applications.
Individual Axles, Rear Axles, Drive Flanges, Knuckle overhaul kits, wheel bearings and more.
Old Sep 2, 2013 | 10:06 AM
Bumping this one back up to the top.
Old Sep 25, 2013 | 04:26 PM
Give us a call to get the best pricing on our Nitro alloy axles for your Toyota today!
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
