Just Differentials Speciality Tools
Old Feb 19, 2015 | 04:26 PM
justdifferentials's Avatar
Differential work requires a few special tools to do the job properly. Just Differentials stocks all of them. You can find all the tools you need to rebuild or repair your differential here. All tools are non returnable.
Differential Bearing Puller Tool - $295
Side & Pinion Bearing Puller Tool with Large Clamshell - $400
This tool is mandatory if you work on differentials regularly as it allows you to remove the bearings without damaging the bearings. This saves you money by you reusing the side bearings instead of destroying with some 2 or 3 jaw bearing puller. This tool works in conjunction with your 1/2" impact gun and it is mandatory that the bearing race is used when pulling the bearings! Replacement parts are available if you wear items out over time also!
EMAIL to info@justdifferentials.com
Call us at 866 349 6801, or at 509 888 2953
justdifferentials
14
Jun 11, 2017 08:36 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
PureTacoma_Tundra
Vendor Advertising
Sep 6, 2015 06:38 AM
