Crossmember/Skidplate Mounting system, Vibration dampening
Old 06-25-2012, 10:42 AM
FormerVendor
Gravel Maker's Avatar
Smile Crossmember/Skidplate Mounting system, Vibration dampening
This is what you need to make that Crossmember bulletproof and still vibration dampening, it comes with everything and is made of 2.0" DOM with a .25" wall and .375 Flat Bottom Tabs for frame mounting (we can replace those with 1.75" or 2.0" Radius Tabs for tube mounting). It comes with grade 8, 9/16" bolts with Lock nuts, and a 1/4" Grease Zirk installed, 4 high quality Bushings, and an inner Sleeves Cadmium coated. We add the Grease Zirk so that you don't need to use greasable bolts, we think of greasable bolts simply as a weak link waiting to break (why would you want to drill a hole in a perfectly good bolt anyway?). They are 2.75" wide and are sold in pairs.
The first one here is for when you want the bushed sleeve to be part of the crossmember...
And here is a new variation, same price, more options for you This one makes the busing part of the chassis and you could simply cut off the tube cutout flat to add it to a flat sided frame...
They are $49 a set before the pirate discount!
We also sell the Bushed sleeves seperately with a grease zirk bushings and sleeve for $16.50, and this is .25 wall DOM, we can substitute 1.75" x .120 wall for $3 less...
http://www.ruffstuffspecialties.com/...g/XMEMKIT.html
Old 09-07-2012, 10:26 AM
FormerVendor
Thumbs up Crossmember/Skidplate Mounting system, Vibration dampening
A great way make and or repair your x-member !!
justdifferentials
Just Differentials
09-17-2015 06:14 PM
lectric80
08-11-2015 12:02 AM
Flossy
08-05-2015 05:14 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Crossmember/Skidplate Mounting system, Vibration dampening
