Marlin Crawler is now stocking Red Line's high performing Shockproof Gear Oil!
Old May 15, 2013 | 07:30 PM
BigMike's Avatar
We are now carrying Red Line's Shockproof Gear Oil and it is unlike anything you've tried before. The first thing you'll notice is that the bottle lacks a weight rating. This is because Red Line's Shockproof technology is completely different from conventional lubricant technology. First, in high pressure use such as slow Rock Crawling, the special design of this oil reduces the thinning effect and metal-to-metal contact producing an effective rating of a 250-weight gear oil. Then, as RPMs increase, it provides three-times the viscosity in thin layers found in high speed applications providing less drag and a fluid friction comparable to a 90-weight oil.
Compared to typical gear oils, this Shockproof Gear Oil has 40% lower coefficient of friction yet has a 250% higher load-carrying capacity. This is great news for the slow moving and high pressure environments that Rock Crawlers are exposed to, and for anytime you really need to input a lot of throttle. In addition, Red Line has verified this oil to run 25- to 75-degrees F cooler in circle track, road racing, and off road racing. It truly provides unequaled protection for heavy duty and competition uses combined.
Sold individually in 1 quart bottles, or in a Set of Three at a reduced price.
Click here for more info: http://www.marlincrawler.com/hardwar...hetic-gear-oil
Old May 15, 2013 | 07:37 PM
BigMike's Avatar
In conjunction with this Round of Maintenance May, we are including three quarts of this excellent oil at HALF PRICE when you purchase any High Quality Yukon Setup Kit! This is a savings of almost $25!
Click here to check out our Setup Kits: http://www.marlincrawler.com/differential/setup-kit/
Click here for more info on Maintenance May: https://www.yotatech.com/forums/f225...rawler-268479/
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
85run
Jul 8, 2015 11:20 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
