toyotafiberglass- Stew from Hawaii
well with covid , no staff , and everything that has happened ..
its now time to get back on this thing , its been here wayyyy to long . Delivery date is coming very soon .
I'm not a fan of cutting for the shock towers , so I streched the inner wheel house for them to fit .
so .. cab coming off , stripped now and sending out for blasting
well stews build is now in the works again ..
working on a few pieces .. frame is just needing final welding and off to the blaster .
working on the HVAC system .. what a mess!!
of course all the foams crumbled/disintegrated as soon as they were moved . disassembled all 3 boxes , cleaned doors , heater motor squirrel cage and motor , A/C evaporator
new o rings .. boxes into our parts washer and cores pressure checked , and all cleaned , new foam .. and back together .
not really a restoration , this truck isnt here for that , but more of a "re-new" .
well after some medical issues , I'm back on it .
frame now done , blasted , POR15 .
locker installed , front and rear assembled ... all new hardware .
cab and box blasted , and being repaired , and prepped
work continues , no corners taken , even where you'll never see , Inners POR15'd
some seam seal , where toyota missed LOL
cab rust repaired
and we are getting close to paint !
cab rust repaired
