Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - S/C 5Vzfe + much more > Joels Build
Old Apr 4, 2014 | 05:39 PM
  #41
slacker's Avatar
Joels back ...
tranny problems , diagnosed as sencros.
Joel is planning a long Alaska trip this year , so he want his runner in "tip top " shape .. so , we ordered a marlin tranny .
Joel wanted to keep it looking nice , he's saving up for duel transfers , and also 3 link front an rear ? (not positive just yet) as well as full custom hi clearance body . Joel decided he wanted the the cast part of the case blue , so we complied with his wishes ..
we are also up dating some of the engine colors for him .. he wanted a "wrinkle" coat powder on the valve covers ..
so all torn down , cleaned , sandblasted , back together and now ready for some powder
Old Apr 4, 2014 | 08:52 PM
  #42
kawazx636's Avatar
What are you using for wrinkle powder coat??
Old Apr 5, 2014 | 09:11 AM
  #43
DossCable's Avatar
Its an enamel wrinkle coat from prismatic powders. Ive heard good and bad things about the application of an enamel wrinkle coat... hopefully Corey can work his magic and they turn out ok?!
Old Apr 5, 2014 | 09:18 AM
  #44
kawazx636's Avatar
I'm interested to see how it turns out. I still need to powdercoat my valve cover, but I'd rather do a wrinkle coat instead of the gloss or matte red powder that I already have.
Old Apr 5, 2014 | 03:38 PM
  #45
slacker's Avatar
they didn't wrinkle ? don't know why ...
also something I never had happen before !! 2 different colors , same oven , same batch ..
so I ended up blasting the bolts again and re powder coating again , but still no wrinkle
they do have a black "fleck" though , and I think look really good
I guess you'll have to decide though Joel
Old Apr 5, 2014 | 08:46 PM
  #46
kawazx636's Avatar
What probably happened was the valve covers are larger AND aluminum so they take longer to heat up thus increasing flow out time. The bolts will heat up and flow out almost instantly. This heating time differential may have flowed off the powder on the bolts by the end of the bake time. Also, I've noticed that powdercoating goes on much more even and thicker over a sandblasted surface and I think the results are much better. Sometimes if I'm having trouble getting a good coat on a part, I'll heat it up first and put a hot coat of powder on it. This usually helps solve the "polarity" issues you can have in tight corners and holes.
I like your little bolt holder thing-a-ma-jig too! I need to make me one of them
Old Apr 5, 2014 | 08:48 PM
  #47
kawazx636's Avatar
Ooo, another problem could have been that the bolts may have had some sort of coating on them before you sandblasted them that reacted with the powder when baked.
Old Apr 6, 2014 | 09:09 AM
  #48
slacker's Avatar
I think this was it ... bolts were also on the mid rack under the v/c's ..
also , I was thinking the smoke could have had a reaction to the bolts ? as much as I cleaned and even sandblasted the inside , you cant get all the oil off , so there was some smoking
ohh , and the bolts were sandblasted the first time as well , so there was no contaminants.
any way , sandblasted them again .. man that powder coat is tough had to turn up the compressor to 140PSI , and re-coat , bake , and done
Old Apr 7, 2014 | 05:33 AM
  #49
kawazx636's Avatar
That makes sense too. I've powdercoated some "smoking" parts too and haven't had a problem, but that was typically with black powder so I'm sure it masked any discolorations. It's crazy how the stuff works - both chemically and mechanically. It's amazing how tough the stuff is - My Eastwood kit is by far, one of the best investments I have made! My motto has been "if it can fit in the oven, it gets powdercoated." I just wish my oven was big enough to fit my whole truck!
Old Apr 7, 2014 | 05:25 PM
  #50
slacker's Avatar
yeah .. all a learning process as well , as we go .
I second on the "best tool" .. I really love it
Old Apr 8, 2014 | 05:29 PM
  #51
slacker's Avatar
rolled Joels rig in , and got to work ..
Joel has decided to get some anodizing done , and a little more powder coating ..
also , old tranny out
Old Apr 13, 2014 | 07:35 PM
  #52
slacker's Avatar
well Joel drove off on Friday ..
tranny swapped , and powder coated parts added ..
Old Nov 25, 2015 | 05:24 PM
  #53
slacker's Avatar
well Joel is back
apparently , this engine liked the H2o .. or maybe not !
Joel brought it in with a visible crack on the block , as well as oil and coolant loss
engine out .. time to tear it down so .. started the tear down (NEW, used engine in the background )
yep .. as expected .. DAMAGE
2 rods broken .. good job Joel !
Old Dec 2, 2015 | 04:35 PM
  #54
slacker's Avatar
so the build continues ... Joel has been doing a great job , and learning well
replacement ready to go in
Old Dec 4, 2015 | 04:13 PM
  #55
slacker's Avatar
Joels Engine is ready to go in , but First we gotta get the new 4:88's in ...
Old Dec 4, 2015 | 06:31 PM
  #56
slacker's Avatar
also just a mention on the "NEW" Marlin transmission now that he has some KM's on it .
Joel is NOT happy with it .. it is worse then the core he sent in . unfortunately , shipping is to much money for them to "fix" the problem as Joel has to pay . he's really disappointed !
Old Dec 6, 2015 | 12:30 PM
  #57
yotes86's Avatar
Thats not good, they cost a few grand and they sent out a product with issues and wont deal with it?
Side note I really like the blue accents on the motor, I need to do that on mine!
Old Dec 8, 2015 | 04:27 PM
  #58
slacker's Avatar
and a new heart in place
Old Dec 10, 2015 | 03:57 PM
  #59
slacker's Avatar
joel wanted some of my hi clearance fenders , and a smoothie cowl ... installed , removed , prepped , primered and reinstalled ...
all good , joel is on his way home .. happy holidays !
Old Jul 9, 2023 | 10:13 AM
  #60
slacker's Avatar
Joels back !!
this time for a body swap . His original Blue runner is in rough shape body wise .
he bought my sons 4Runner about a year ago and has been driving that . toyotafiberglass - My sons 4Runner - YotaTech Forums
so, body swap , added 3" lift , 35's on 16s and the S/C 3.4
enjoy the pics
MadMax48
Mar 3, 2020 10:33 AM
1965chevy
Sep 20, 2015 07:33 PM
LotOMiles
Sep 14, 2015 11:45 PM
