Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - #001 Mirage
Old Dec 2, 2020 | 03:33 PM
slacker's Avatar
In 1982 , in Canada there were only 500 and they are all # plated . I believe it WAS a Toyota limited edition . If you look at the chrome tail lamps , and the original low mount chrome mirrors , they are Japanese manufactures , Port installed pieces , and dealer pieces , are always "North American " made .
USA I think copied it for there dealers in 1983.
I had a customer in contact with me for many years about restoring his . I offered many times to buy it , and he said he would never .. well , life got in the way , and I bought it .
Old Dec 2, 2020 | 03:35 PM
slacker's Avatar
well , its started .. I needed space in my lot , so I had to remove a few things .
dash is butchered , box is beyond repair .. and frame is a perfect example of where NOT to anchor your chain when stuck !
Old Dec 3, 2020 | 10:05 AM
slacker's Avatar
started doing a few things .. progress is being made
started by blasting a few things and hitting them with some powder
fixing and straightening
Old Dec 28, 2020 | 03:21 PM
slacker's Avatar
so lots of cleaning and buying parts ..
I'll let the pics do the talking
powder coated and rebuilt
Old Feb 9, 2021 | 08:14 AM
slacker's Avatar
air cleaner and snorkel , check .
Old Jul 4, 2021 | 09:15 AM
slacker's Avatar
been restoring a bunch of the parts and pieces .. more pic porn
Old Jul 4, 2021 | 09:40 AM
old87yota's Avatar
Looks great!
What were you doing with the bolts and misc. hardware in the third picture?
Old Jul 5, 2021 | 07:00 AM
slacker's Avatar
Originally Posted by old87yota
Looks great!
its my re-plating yellow cad . I'm replating all the nuts, bolts and brackets back to original .. doing that in house , those are fresh out of the tank and drying
Old Jul 5, 2021 | 03:10 PM
old87yota's Avatar
Sweet!
Old Jul 6, 2021 | 07:40 AM
slacker's Avatar
Sweet!
most of the engine parts from my MOJAVE and MIRAGE had the OE parts and part #'s on them , I'm also using those to have them "re-made"
so most of the parts will be original , rebuilt in-house , and have the part # decal on them .. just like factory
Old Jul 6, 2021 | 12:36 PM
old87yota's Avatar
You are pulling out all the stops on this one! I love it!
This will be a true restoration!
Someday I want to do something like this too.
Keep us posted!
Old Jul 16, 2021 | 07:39 AM
slacker's Avatar
couple more pieces done and packed away
Old Sep 20, 2021 | 08:38 AM
slacker's Avatar
some pieces coming back from my decal guy for approval , some still have to be "chromed"
engine back from the machine shop , and starting to go back together , short block done .. now I need some yellow bolts
signal lamps done .. took some time today for a little more restoration .
signal lamps for both MIRAGE and MOJAVE projects .
couple of the housings were broken , so I "glued" them back together , when Dried , I put them into the shop parts washer along with the lenses . (over a couple days)
now all dry from that , I repaired the sockets , and wiring , and tested !
I then polished the reflectors and painted the housings , put in the new bulbs with some dielectric grease .
I found some new rubber from a hardware store (for screen door ) and made some new gaskets , polished the lenses with carnubia wax , and back together .. tested and all work great .
Old Sep 20, 2021 | 08:43 AM
slacker's Avatar
also , in case you haven't see it , this is the truck
Old Sep 21, 2021 | 11:10 AM
Discombobulated's Avatar
I’m sure this will be amazing just like the rest of anything you do!!!!!
Quick question on the spline you are using for your housings, I just got some new lenses for my rear lights and repainted my reflectors in the front, I was on a mission for some new seals and spline came to mind but everything I looked at was really hard and had no play to form a seal…..is this spline in your pic pliable?
Anyway can’t wait to see this when it’s done!!!
Old Sep 22, 2021 | 09:34 AM
slacker's Avatar
thanks .... yes , the spline is a PERFECT replacement !! very flexible ... its hollow in the center to allow for compression , it works GREAT !
Old Mar 7, 2023 | 07:34 AM
slacker's Avatar
was able to get my front drive shaft done over the last couple weeks .
powder coated and completly rebuilt , and now all wrapped up and put away in anticipation of the build .
Old Sep 15, 2023 | 11:45 AM
slacker's Avatar
havnt been able to do much on my Truck , working on customers .. But I was able to knock out a couple pieces ...
I have been searching for 2years for some rare A/C parts with no luck . A new friend had some on a project he was working on , and lent them to me so I could
make my own .
just have to powder coat them now .. and done !
