Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
Looking for an HONEST/Experienced mechanic in Tacoma, WA.
Old Jul 30, 2009 | 10:37 AM
A.Wilson013's Avatar
Does anyone know of a fairly well priced, and very well experienced Toyota mechanic, or any mechanic, really, in the Tacoma area? I could go as far as Olympia or Seattle if needed. We just moved up here not long ago.
I am just looking for a few basic upgrades/repairs. Mostly electrical. For my 1987 22RE 4Runner SR5.
All input is greatly appreciated.
Alex
Old Jul 30, 2009 | 11:11 AM
Corey's Avatar
Co-Founder/Administrator
Auburn Car Repair
http://www.auburncarrepair.com/
He is a Jeep guy, but he has been doing the FJ Cruiser body mount chops, and he will be installing my new rack in the future for me.
I have heard he does very good work.
I stopped in and met him last year to shoot the breeze with him.
Not sure how well he may know the engines, but it might be worth giving him a call.
Old Jul 30, 2009 | 04:05 PM
kiyobrown's Avatar
I have taken a couple rigs to a guy just over the bridge in Gig Harbor. Graff's Automotive Repair. I have had good luck with him, but call and make an appointment. He runs all off of word of mouth, and he is busy. My wife used to run a bar in Gig Harbor and is friends with him. That was the only reason I found out about him.
(253) 851-9974
2318 Point Fosdick Dr NW Gig Harbor, WA 98335
Old Jul 30, 2009 | 04:22 PM
Tofer's Avatar
Sponsor
what are you looking to do? depending on what you're looking for i may be able to help.
Old Jul 30, 2009 | 08:00 PM
Edit** Corey, I sent you a PM about a week ago asking about local camping spots that are not in high-traffic areas, did you receive that?**
Corey, Kiyo and 02/89. Thank you for the tips, I will pencil them down.
Tofer,
I have not driven this thing in years. Everything worked great ( I think ) when I put it up but now there are a few problems.
1. My brights- when I pull the switch in and hold it, they are on just fine. When I push it out to leave them on, my headlights turn off.
2. Rear window- I am pretty sure it just needs the little motor that's in the tailgate.
3. Power windows and locks- They work about 1 in 10 times I try and use them... And the windows hardly go up or down when they do decide to go.
4. Also just a general tune up-- Change the spark plugs, distributor cap, wires, rotor, adjust the timing, adjust the valves, new air filter, synthetic fluids in the
engine, tranny and t-case.
Old Jul 30, 2009 | 08:18 PM
Tofer's Avatar
Sponsor
my 89 does the same thing with the brights... so i gotta figure that one out myself..
the rear window is pretty simple to swap out.
the power window/lock issue sounds like it could be the relay.
the tune up should be a DIY... minus the valve adjustment.
if you want to save your self a bunch of money and do it your self with help let me know.. i have a shop space to do it if you dont have a place to work on your truck.
Old Jul 30, 2009 | 08:43 PM
myyota's Avatar
The headlight problem sounds like a headlight switch, you might be able to clean the contacts in the switch, they become pitted after years of use, or you could replace it.
Old Jul 30, 2009 | 08:52 PM
Plumbrbob's Avatar
valve adjustments is a simple procedure just call me up if you need a hand if your working out of tofers shop
Old Jul 31, 2009 | 01:56 AM
Wow, guys. Tofer and Bob, could I get your e-mails? I would like to save some money, but I literally have no time for about another month. I would like to be able to get in touch with you then and try to get these things figured out.
Again, thanks a lot.
Alex
Old Jul 31, 2009 | 03:15 AM
Corey's Avatar
I do not recall getting one, I will have to go through my PMs later.
Tons of spots around here, in fact I am vacationing very soon for a whole week up at Greenwater on Huckleberry Creek.
Not to far away, and lots to do such as swimming, mountain biking, ect.
Old Jul 31, 2009 | 03:14 PM
Plumbrbob's Avatar
just PM me I log into Yota tech daily
smthwsn357
May 1, 2024 07:28 AM
polo451
13
Nov 20, 2016 07:49 PM
Tacoma1313
Aug 17, 2015 05:44 PM
makemusic116
Aug 2, 2015 05:23 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
