93-98 T100s (Build-Up Section) Post your build-ups here
Mikes T100 Build Thread
Old Feb 10, 2014 | 03:53 AM
  #121
RBX's Avatar
RBX
That's what I thought. Thanks
Old Feb 10, 2014 | 05:30 PM
  #122
Toyota~Boy's Avatar
We'll I finally got around to installing my Aisin Manual locking hubs. My hubs are factory off a 3rd gen pickup. There not all that pretty due to grease and grim. But they are really smooth working hubs. I'm hoping that these will help me out on gas a little. When the weather gets pretty and I clean my truck up I may remove them and re paint them if needed.
Old Feb 12, 2014 | 07:23 AM
  #123
jaretstuff's Avatar
So are the 35s still a go. I am really anxious to see how they fit
Old Feb 12, 2014 | 07:54 AM
  #124
Toyota~Boy's Avatar
Yep I believe so. Taxes should be here tomorrow
Old Feb 15, 2014 | 06:22 PM
  #125
jaretstuff's Avatar
So are 35s a go
Old Feb 18, 2014 | 05:23 PM
  #126
Toyota~Boy's Avatar
Time for a Update....
Ordered a few parts today
5" suspension lift kit
Cold air intake
New exhaust system from manifolds back
1" wheel spacers
All four factory Balljoints (expensive)
My 35" (315/75r16) tires are bought, mounted and balanced but not installed. I went with the new MasterCraft Courser MXT's
Tomorrow I will be ordering my Steel to build my Custom 5' bed.... Can't Wait for stuff to arrive!!!!!!!!
Old Feb 18, 2014 | 05:33 PM
  #127
jaretstuff's Avatar
Can't wait to see them. Do you think they would have fit with your current lift
Old Feb 18, 2014 | 05:53 PM
  #128
Toyota~Boy's Avatar
Yeah they do fit. However they rub my steering components. That's why I bought the spacers. I wanted the extra lift because I've never owned a lifted IFS toyota. I mean yeah I've had BJ spacers but nothing seriously lifted. My truck is a DD and I don't see a SAS in the future of this T100. So why not. I mean I do a lot of wheeling but nothing that severe. So the IFS will be plenty for me. I do believe that a 37" tire mounted on a properly backspaces wheel will fit once the other lift is installed. I'm also keeping my current lift too. So I'm going to have a total of 6-7 inches of straight up suspension. No body lift at all... My current lift is coming with Rear blocks tho however sky's off-road carries lift springs for the T100 so those will be my future plans.
I'm into this truck now for around $4000.00 including everything I've ordered today. It still looks like a POS tho lol... Once my bed and stuff is built I'm going to paint it. Unsure of color yet tho. I'm thinking of keeping the factory color.
Old Feb 18, 2014 | 06:39 PM
  #129
jaretstuff's Avatar
Wow only in 4000! Jeez I'm in like 4500 and yours is way better than mine
Old Feb 18, 2014 | 06:52 PM
  #130
Toyota~Boy's Avatar
Mines no different then yours. I only gave $1000.00 for my truck so that helped a lot too. I'd have way for then that In it but I work at a salvage yard part time that has 5 T100's so I get a lot of my replacement stuff for free. I've even added stuff to my T100 that it didn't come with from factory. I just can't wait for my bed... I'm more excited about replacing my bed more then anything else.
Old Feb 18, 2014 | 06:56 PM
  #131
jaretstuff's Avatar
Flatbed I assume
Old Feb 18, 2014 | 07:08 PM
  #132
Toyota~Boy's Avatar
Yeah flatbed... If you go back a page or two on my thread you will see a drawling that I made showing my design that I'm making.
Old Feb 18, 2014 | 07:12 PM
  #133
jaretstuff's Avatar
Dang Shoulda seen it thanks for the info
Old Feb 18, 2014 | 07:20 PM
  #134
jaretstuff's Avatar
This is an unclose view. They come in 15s to FYI
Old Feb 19, 2014 | 01:36 PM
  #135
dsal_86Yota's Avatar
sounds like you got a good plan. Cant wait to see the bed. I checked out those tires. Good prices. Might look at some of my 86, Im just gonna go with a 33 for now.
Old Feb 19, 2014 | 04:06 PM
  #136
Toyota~Boy's Avatar
We'll today went well..,
I received the rear section of my lift so I installed it. Of course it's just blocks so not really a hard nor long job. I was really disappointed to find out that my driveshaft was 3" to short. Summit never said anything about that. I though I could bolt it on and go. Guess not. So I spent the evening extending my rear driveshaft. Sorry guys I have no pics of doing it. I was so irritated and trying to find a solution was killing me. If you guys are familiar with the slip yoke section of the driveshaft then you will understand what I'm going to describe.
I only had 1" of shaft slid up on the driveshaft. This gave me a extreme vibration. So I used a old front driveshaft and cut 3" off the slip yoke shaft thingy. I then slid it on the driveshaft then I slid my existing yoke piece onto it. I then shoved them together and welded them up. I don't it that way so I new that no matter what is be perfectly straight. I then removed it grinded the welds down and reinstalled it. NO MORE VIBRATION AND PLENTY OF SHAFT TRAVEL IN AND OUT.
Tomorrow I will receive the front and get it installed giving me a total of 6" lift front and rear.
Old Feb 19, 2014 | 04:40 PM
  #137
jaretstuff's Avatar
Sounds good glad you got some of it done. That sucks about the driveshaft being too short but glad you used some "murican" ingenuity. I've been meaning to ask what is the front lift. Does it drop the front suspension or what does it do.
Old Feb 19, 2014 | 06:36 PM
  #138
Toyota~Boy's Avatar
The front end consist of a few cross members and two large spindle drop brackets. Basically I'm dropping the entire front end 4". The upper a-arms do not move tho. They stay in there factory positions. The front diff and lower A-arms are the only things being dropped. The steering stays in the same position as factory. This is achieved with the spindle bracket.
Old Feb 19, 2014 | 06:38 PM
  #139
Toyota~Boy's Avatar
Oh by the way. A 3.4 with the Automatic tranny has a front driveshaft that is about 3" longer then my stock driveshaft. I already have one if those so I won't have to make or adjust the front driveshaft. It's just a simple swap.
Old Feb 19, 2014 | 06:40 PM
  #140
jaretstuff's Avatar
10-4 I know exactly what you mean now. Should look wicked once it's done. Decided on a color yet for it. If you go satin or matte a tan or od green would look very cool. Or if your going gloss maybe red or blue.
