brake caliper bolt?
Old Jan 1, 2012 | 11:32 PM
Lena's Avatar
brake caliper bolt?
ok soo, i have discovered that the brake caliper case thing (do not know name) is missing a bolt, i went to a local harware store and found a similar bolt (did not work) so than i went to wrecking yard and took bolt off a t100 the bolt said it was a 10, the bolts on mine were 11 but looked the same, soo that did not work either, im not sure what to do from here.... help?
Old Jan 2, 2012 | 05:37 AM
waskillywabbit's Avatar
Buy one from the dealer They probably have one in stock.
:wabbit2:
Old Jan 2, 2012 | 05:40 AM
rworegon's Avatar
Can you pull the same one from the other side for reference when selecting the bolt? The True Value hardware here has little pullout tray will all sort of metric bolts. ACE or a local farm supply probably has the same.
Old Jan 2, 2012 | 11:02 AM
dmwahl's Avatar
2nd wabbit. The dealer should have one. It's probably higher grade steel than the hardware store will have as well.
Old Jan 2, 2012 | 03:54 PM
Lena's Avatar
i did pull one off the other side and took to harware store, i couldnt find one... i work at home depot and we dont carry them either, so i will try dealer next
Old Jan 2, 2012 | 06:15 PM
rworegon's Avatar
Maybe you'll luck out and the dealer will have it on hand.
88sasturbotoy
Jan 30, 2026 01:57 PM
jashoeuh
Nov 18, 2024 08:08 AM
garagespace
Oct 11, 2015 10:59 AM
Sep 4, 2015 09:27 AM
ty1er
Aug 1, 2015 11:53 PM
