Yellow check engine light .........wierd maybe long
Old Dec 26, 2002 | 11:08 AM
bamayote's Avatar
i've got a 99 tacoma 4wd v6 with 100k on it. i was pulling my 16ft tandem axle trailor the other day after i'd rewired it (let a friend borrow it for the last time). i had to rewire the plug and the trailor brakes. let me make the facts simple.
1. i was pulling the trailor without a load
2. only pulled it for 2-3 miles to make sure everthing was working right.
3. pulling in 4wd (needed 4wd to get it back in my barn)
4. i'm only pulling 6 volts in my brake contoller digital read out. each brake pulls 3 volts.
5. the plug is intact and both male and female ends are good. continuity is good and there's nothing touching inside the plugs.
6. put the trailor up, and the truck sat for 20 min.
7. i took off to a fire call and when i got the the fire station the check engine light came on.
8. all fuses are good, all fluid levels are good. it's got a new air filter, new oil and filter.
here's where i may have gone wrong. i disconnected the battery and it went away, but i havent pulled the trailor since.
any suggestions?
sorry for the long post. i tried to make it short.
thanx
brad
Old Dec 26, 2002 | 11:56 AM
Jay's Avatar
Jay
Check Engine Light is in no way related to the brake, tail, or turn signal lights.
If the light comes back on, go to Autozone and have them scan for codes. Then report back here with the code #.
Until then dont worry. Enjoy the Holidays.
Jay
Old Dec 26, 2002 | 12:22 PM
bamayote's Avatar
Thanx Jay.............will it give a code if the light is not on?
hope i'm not a bother by asking another question, but the light was turned off with the disconnect of the battery.
thanx again
cya
brad
Old Dec 26, 2002 | 12:41 PM
Jay's Avatar
Jay
hope i'm not a bother by asking another question......
Not a chance.
By disconnecting the battery, you erased the codes that were stored in memory. Its normal for the light to go off after that.
Jay
Old Dec 26, 2002 | 01:20 PM
bamayote's Avatar
thanx again jay!
it's so nice to find nice folks on this forum....as opposed to another forum i know! lol
Old Dec 26, 2002 | 09:36 PM
Jay's Avatar
Jay
other forum?
I didnt know there were more.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
