yakima loadwarrior...
Old Jun 5, 2004 | 09:47 AM
smr4runner's Avatar
Hey Joe,
I usually only take the rack off. All it requires is loosening the four support brackets.
If I need to take off the crossbars I do have remove eight bolts (two on each base of the Conferr mounting brackets). However I only remove the crossbars when I wax the roof.
Old Jun 5, 2004 | 10:10 AM
SkyRat's Avatar
Originally Posted by anthraciterunner
Just a little south of you, in Glendale. I haven't gone camping for like almost 7 years now. Looking to get some done this summer though. What weight limit should I keep in mind if I am going to use the yakima bars and mounts? I like the idea of being able to remove the rack quickly if need be.
Hey smr4runner, can you remove the conferr mounting brackets as easily as the yakimas?
I don't really know. But, the thing is solid. It is expensive to go all the way with the landing pads, control towers and bars, but I think it is worth it. You could also get the rack and mount it on the factory rack and nail the rest of the package when you can spend the extra cash. The whole rack and bars pop off quickly, leaving only the landing pads attached. You probably want a second person just to help lift the rack away from the truck without scratching. The same brackets that come with the rack will hold it to your factory setup or to the Yak bars. If you want any pics I have plenty I could e-mail you.
Athansinis
Jul 27, 2015 08:38 AM
motobrandt
Feb 21, 2006 09:17 PM
90WhiteSR5
12
Jan 27, 2005 02:27 PM
UKMyers
11
Nov 24, 2003 09:46 PM
SkyRat
Nov 4, 2003 05:49 AM
