won't idle, please help
Old Apr 7, 2004 | 06:38 PM
joe d95's Avatar
I've changed the head gaskets on my 95 4runner (3vze). Everything went back together with some problems along the way. I had difficulty setting the timing correctly but finnaly finished it. It starts right away but will not idle at all. My question is, did I do the timing incorrectly or is there something else I'm missing. All vac lines are in their original places.
I did have to remove the air plenum and clean out the black gunk that accumilated around the egr tube.
Old Apr 7, 2004 | 06:48 PM
MTL_4runner's Avatar
Did you jumper the OBD port while setting the timing?
Old Apr 7, 2004 | 06:49 PM
joe d95's Avatar
yes I did jump the OBD. I can start it but it will not idle. I have to hold throttle open just a little to keep it running.
Old Apr 7, 2004 | 07:25 PM
AgRunner06's Avatar
I would double check the vacuum hoses. I think there is also an IAC that controls the idle. You may want to look into that. I'd listen around for some vacuum leaks too.
Good Luck
Old Apr 7, 2004 | 07:45 PM
SoCal4Running's Avatar
vacum leak or TPS out of adjustment. My 0.02.
Old Apr 7, 2004 | 08:16 PM
fooddude's Avatar
There is a hose rite next to your airbox, i think it is called the airintake silencer, but it is attached to this little box. Anyways the other day my runner wouldnt idle either exactly like yours, and it was because this hose became disconnected. I put it rite back on and she worked like a charm.
Old Apr 8, 2004 | 04:52 AM
Ok to me that sounds like a vacuum hose or two not plugged in. Could even be a leak at the manifold causing this as well...look at all gasket areas too. Look over the engine carefully, I bet something got missed or is not sealing. You can use some carb cleaner to check for leaks (spray it on small areas of the engine while it is running. You will hear an RPM change when you find the leak.
Blamalam
Mar 12, 2022 07:34 AM
bighaydn
Aug 4, 2015 07:17 PM
87toyy
Aug 4, 2015 04:51 PM
94yotaky
Jul 23, 2015 07:50 AM
kyletbert
Jul 17, 2015 11:39 AM
