Winches and Water Crossings
Old Feb 13, 2003 | 10:12 AM
Roadrunner's Avatar
I thought I read somewhere of a 4Runner's Warn winch getting fried after crossing a stream. Is this an inherent problem with front bumper mounted winches? Or can winches be submerged or gotten wet as long as the seperate solenoid pack (if your winch has one) is mounted up high in the hood?
Old Feb 13, 2003 | 11:00 AM
WATRD's Avatar
The winch itself is sealed and can be used even when it is under water. The solenoid pack is a bit more fragile and while it can be submerged, it's best to dry it out before you try to use it...
Old Feb 13, 2003 | 11:06 AM
Cebby's Avatar
What about those winches with the integral solenoid, like that Warn Thermometric? Is the solenoid waterproof on those?
Old Feb 13, 2003 | 11:12 AM
WATRD's Avatar
Supposedly the integrated solenoid packs are water tight, but that is not what I have observed. I would be pretty cautious about dunking them because you can't just pull the solenoid and repair it, you have to send the whole unit back.
BeMiceElf
Oct 10, 2015 09:40 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
skypilot
Aug 25, 2015 01:09 PM
DirtRoad93
Aug 23, 2015 05:50 AM
priest16
15
Aug 6, 2015 07:43 AM
