Will this work on 3rd gen 4runner? (lighting)
Old Apr 12, 2004 | 02:00 AM
SQRLNTS's Avatar
Just wondering if this would work Lighting tip and if it would has anyone tried it. In theory it should but tracking down the wires from the steering column might be a
Thanks
Old Apr 12, 2004 | 04:09 AM
Mossback74's Avatar
It would work but I wouldnt do it. Harneses could burn up, and not to mention the increased bulb wear.
If you need the light, get Hellas
Old Apr 12, 2004 | 04:53 AM
96LtdYota's Avatar
hey, I wouldnt do this. I used to have both high and low together in my PIAAs, and after having them on for 20 something minutes, it actually burned(not fire, but blackened) my reflector and the inside of the glass. and these were regular H4 light bulbs, the same used in the 3rd gen runners.... take my advise and dont do it. like Mossback said, just get some hella 500s. they will give you all the light you could ever ask for.
Old Apr 12, 2004 | 05:43 AM
SLC Punk's Avatar
I wouldn't do it either.
I think this is intended for vehicles with two different lamps (like GM trucks).
Old Apr 12, 2004 | 10:36 AM
User 051420's Avatar
I know JC Whittney sells something like that. Maybe it's PP. It's an expensive little box you wire your lights through. Silly.
I know that I can position my high beam stick in just the right spot to get the same effect.
Old Apr 12, 2004 | 03:14 PM
Jason B's Avatar
Sounds like a fire waiting to happen. If there was a relay involved, I'd think about it.
Old Apr 12, 2004 | 05:23 PM
SQRLNTS's Avatar
Thanks for the input guys.
AustinTaco
Aug 22, 2022 10:45 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
westbound
Jun 7, 2002 03:30 PM
Gene
19
Jun 3, 2002 07:07 PM
