Will a Double Din Headunit fit?
Old May 6, 2009 | 02:59 PM
hector200sx's Avatar
I have heard that you can use a scion stock radio in a 4runner with the stock harness is that true?
Old May 6, 2009 | 03:20 PM
SoCalPaul's Avatar
My understanding is that there may be some minor trimming of the 4Runner bezel needed.
Old May 6, 2009 | 06:46 PM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
x2
https://www.yotatech.com/forums/f2/2...-radio-128951/
(picture of scion unit installed)
Old May 7, 2009 | 08:00 AM
yeah i did some searching unless i find a scion for super cheap it seems like its way easier to just get a aftermarket deck
Old May 7, 2009 | 07:05 PM
  #25
fireball's Avatar
Originally Posted by Cbohl51
For the AVN-6620, the unit was too long to fit correctly. It would fit in there, but the wires were pressed against the HVAC ducting, and no room for the cooling fan to pull sufficient air flow. I had to space it out about 1/4 inch. This caused interference with the opening in the console, so had to pull out the trusty dremel, and enlarge the opening a bit. THEN, when the face folds down, it hits the shift lever if it is in park.
However, this is all nothing for the quality of Eclipse.
**edit** forgot that most of the newer model Eclipse Navi units accept the factory Toyota plugs, so no wire harness is needed!
Yeah I am a big fan of Eclipse. Problem with their newer stuff is that the LED colors don't match the rest of the interior. I am thinking about going with a Nakamichi deck in the 4runner. I had a Nak deck in an old Honda and that thing rocked. Very simple and good looking, and amazing SQ.
Old May 8, 2009 | 04:09 AM
  #26
Cbohl51's Avatar
^^I'm not sure about their newer cd decks, but the AVN Models appear to all Illuminate green. The last style before they went to the mainstream design(around 2004-2005ish) allowed you to change the illumination to green or red.
Nakamichi are very nice decks too. I love the plain simple design with great SQ. Makes me a little sad that Eclipse strayed away from this.
Old May 8, 2009 | 06:07 AM
  #27
pdyebrasil's Avatar
Originally Posted by son209
Buy a kenwood. The video bypass is easier to do, they have more inputs/outputs for video and I personal think the fit and finish is better.
I agree that Kenwood makes a great product, but I believe that Pioneer is a better deal. I got Pioneer's top of the line Premier NAV unit for $500. The comparable Kenwoods were all $800 or more. So that's what sold me on it. As for the bypass, it takes all of 60 seconds longer to do it on the Pioneer. Backup camera works great BTW
Old May 8, 2009 | 06:57 AM
  #28
xcmountain80's Avatar
Hmmm I'm having trouble finding their premier line up online, I used to be big in audio way back when but have bben out of it for so long, I Know the PP line is nice. WHich nav unit didi you get for $500. I already have a Garmin 276C so I don't need nav but if the price is right.
Aaron
Old May 9, 2009 | 02:08 PM
  #29
Originally Posted by pdyebrasil
Double DIN will fit. I have the Pioneer Premier AVIC-F90BT. Crutchfield said it wouldn't fit. It looks pretty much the same. I don't have any experience with the unit you are talking about, but I love mine! In my experience Pioneer makes a good product.
How did you change the opening screen?
Aaron
Old May 9, 2009 | 05:24 PM
  #30
I just ordered a AVH-P4100DVD so we'll see how it goes.
Aaron
Old May 14, 2009 | 06:53 PM
  #31
WHat can I do about the power antenna? I have a wire but .....
Aaron
Old May 14, 2009 | 09:27 PM
  #32
pdyebrasil's Avatar
I have the AVIC-F90BT. I just made my own startup screen and changed it in the splash screen menu. I just hooked my power antenna wire up like it's supposed to be. My unit has an option to either put it up when it has power or to only use it when the radio is selected. Not sure about the unit you got though.
Old May 15, 2009 | 05:30 AM
  #33
Do you have a picture of the antenna screen so I Have something to look for. And how did you go about the splash screen? This had to be the easiest mod I've done as everything fits perfectly.
Thank you
Old May 15, 2009 | 08:36 PM
  #34
Well I got it in and what a pain in the ars free mod, I swear the easiest yet! Tight clearances provide a nice OE/ custom look. Cameras to come as the lines are already run.
Aaron
Old May 15, 2009 | 09:02 PM
  #35
Rock Slide's Avatar
You suck.
Old May 15, 2009 | 09:08 PM
  #36
Don't hate the player, hate the game. Bill that USA-SPEC Ipod adapter had to go, it worked alright 1/2 the time and not at all the rest. I will be able to watch the rear facing baby day/night on my monitor (mom likes that feature). It was $399 from http://www.artofsale.net/, which is a steel I might add.
Aaron
Old Jun 25, 2009 | 06:48 AM
  #37
Rock Slide's Avatar
Ok, I blame all of you...especially you Aaron. I just ordered the AVH-P4100DVD & ipod cable. Should be here next week. Looking into back up cams now.
Old Jun 25, 2009 | 07:00 AM
  #38
Hey now don't blame it on me to your wife! I don't want to be on her list, those Bama girls can hold a grudge. The install is straight forward.
1. Pull trim bezel
2. Remove 4 screws on radio (then remove brackets from old HU)
3. Remove 2 screws from HU amp.
4. Splice best buy or other purchased HU wiring harness.
5. Splice in the relay to bypass to circumnavigate video feature.
6. Run ALL video out and in lines you will need.
7. Plug everything in and do a test start up b4 you fully install it.
8. Check and triple check your elec. connections.
9. Install Hu and bolt it up, doing a bezel test fit.
10. Turn the HU on, and tilt the screen all the way back then install bezel.
11. Get your wife and show her how cool you are!
12. Yeah
Yea yea it's a 12 step program.
Aaron
Old Jun 25, 2009 | 10:31 AM
  #39
Rock Slide's Avatar
The HU install itself should be easy enough...I've ripped my dash apart at least a dozen times before
As far as the ipod cable, where is everyone routing that to? I've thought about routing it up thru the small cubby hole next to the e-brake lever...as I don't use that space much anyway. Just drill a hole in the back of it and route the cable thru it.
And yes Aaron, I will tell my wife it's all your fault.
Old Jun 25, 2009 | 11:28 AM
  #40
Jay204's Avatar
ha ha good spend more cash on that truck of yours!! It can only keep getting better right?
....still waiting to do that projector retrofit.....i'll send you a box with ALL the componants lol j/j
