Will A 1997 Tacoma Strut And Spring Assembly Bolt Into My 1997 4runner?
Old Aug 17, 2005 | 06:33 PM
BOSTON4RUNNER's Avatar
Will A 2004 Tacoma Strut And Spring Assembly Bolt Into My 1997 4runner?
hello please advise
I have a line on assembled front struts out of a 2004 Tacoma
will these assemblies bolt into my 1997 4 wheel drive 3.4 liter SR5 4 Runner?
please help, I need to buy them quick if so, going on vacation in a couple weeks so I need to buy them, have them shipped and order some 892s for the rear and diff drop
given that these struts will fit my rig
thanks, tim
Old Aug 18, 2005 | 04:42 AM
<bump>
need to find out quick...as this item is up for sale and need to let the person know either way
Old Aug 18, 2005 | 04:49 AM
bamachem's Avatar
yes. they will bolt on. they have the same upper bolt pattern as your 4runner.
Old Aug 18, 2005 | 04:57 AM
bamachem's Avatar
they will be OK to use, but they may or may not be the same ride height depending on what they're coming off of. if they're off of a 4wd Double Cab or Extended Cab w/ a V6, then they should be about the same ride height as your stock springs (maybe up to a half-inch lower since they will be a touch softer than your stock springs).
Spring Rates:
Tacos ~430#/in
4runners ~450#/in
Tundras ~475#/in
Old Aug 18, 2005 | 06:56 AM
they are tokico struts, rev tek 3 inch spacer with stock non-trd coils
they are indeed off a double cab
Old Aug 18, 2005 | 07:02 AM
bamachem's Avatar
should yeild 2.5-3" of lift for you - prob closer to 3"
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
coryc85
Jul 7, 2015 04:05 AM
HRDC0R19
Jul 5, 2015 06:43 PM
