Wierd noise and vibe
Old Oct 14, 2003 | 08:50 AM
22Ryota's Avatar
My mother drove the truck yesterday and i am hearing some wierd noise now... Driving at low speeds of 10 mph or lower i hear a squeaky sound and can feel a vibration in the floor when the sound happens. The sound is not present when driving at higher speeds... But driving in the parkinglot today i thought something was going to fall off. The sound is kind of squeaky kind of grindy. I have an 87 pickup... I knew something would go wrong.. i just had the major transfluid leak repaired and now this pops up..... I think i am also in dire need of a tune up too!
Old Oct 14, 2003 | 04:01 PM
22Ryota's Avatar
Anyone have any idea what this noise could be... Couldn't be the drive shaft since it only does it at low speed... Checked it today and it is 15 and under...
Old Oct 19, 2003 | 02:07 AM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
First of all... you loaned the truck to MOM Just tell her she wrecked it!(probably offroad!) Have you crawled under the truck to look at everything?
Old Oct 19, 2003 | 04:32 PM
22Ryota's Avatar
Yep... been under the truck looking and everything looks normal... and believe me... Loan is not the word.. it's more like "I paid for your ^&$^ truck you better let me use it whenever i want to!!!!"
Old Oct 19, 2003 | 05:39 PM
joez's Avatar
check the tension on the power steering belt......
Old Oct 19, 2003 | 06:10 PM
KING's Avatar
Tranny??
What kind of a noise............ a whinny noise??
Old Oct 19, 2003 | 08:48 PM
Make sure it's not something simple like a squeeky speedometer cable. I've had a couple of Toyota's with this problem. Freaked me when I first heard it. Lot's of good threads on this subject, just do a search and see what you come up with.
Old Oct 23, 2003 | 05:43 PM
22Ryota's Avatar
It is kind of a whiny squeak... it is only when cruise... When i hit the gas it seems to disappear and also when braking it is gone... But if i am just going down the road with my foot off the gas i hear it and feel a vibration to accompany it in the floorboard... I have been have tranny problems with the thing not shifting at the right points (automatic).
Old Oct 23, 2003 | 08:05 PM
I'm no expert, so if someone else is, please chime in but it might be a good time to change the tranny filter. It's not too expensive and when you do it, make sure and look for and metal shavings or peices attached to the magnets at the bottom of the pan. If you have any metal at all down there, get to the transmission shop ASAP. I just bought a tranny filter for my '91 and it was $18 with gasket. The job took about 45 minutes total and just about anyone can do it.
Old Oct 24, 2003 | 08:57 AM
22Ryota's Avatar
Any articles for information on doing that? I know i would have to drain the transmission and drop the pan but after that it would be helpful to have an article to refer to.
Old Oct 24, 2003 | 10:59 AM
It's pretty easy to do yourself. If you've never done it, consult a Chilton's manual or a Haynes manual. The pan just drop's down, you don't really need to drain anything and then you can fill it with the dipstick tube and a narrow, CLEAN, funnel. I recommend a funnell you are going to use specifically for ATF. The guy at the Auto parts store recommended Valvoline Maxlife, but if you drive it off-road with a heavy foot a lot you might consider a synthetic like Redline..it's good stuff. I recommend you buy about 6 quarts and return whatever is leftover.
Like I said before, I'm no expert, in fact I've only done this once before. So if I'm giving bad advice somebody please chime in here.
BTW, I just bought a chilton's manual the other day and I like it much better than my Haynes manual. Good luck.
Old Oct 24, 2003 | 11:21 AM
22Ryota's Avatar
Thanks Yea i do need a good manual and all.... thanks for the advice hopefully that will fix anything that is going wrong with it... hopefully
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
