Why does my cruise control turn off on some hills?
Old Mar 18, 2004 | 07:26 PM
Yoter's Avatar
Guest
Today I took a road trip and ran into my 4runner jumping out of cruise three times on me. All while going up hills. Does the cruise have a kick off point?
Old Mar 18, 2004 | 07:37 PM
Scofco's Avatar
The truck's on-board computer will turn the cruise off when it senses the throttle near wide open. While going uphill, the cruise control will be adding throttle to maintain the speed you have set. When the computer sees the signal from the throttle position sensor go to near wide open it will disengage the cruise control as a safety precaution.
If the problem occurs on smaller hills the truck may be suffering from a lack of power or performance.
Old Mar 19, 2004 | 03:09 AM
foxtrapper's Avatar
Guest
You may be able to improve the situation by installing a vacuum check valve and accumulator between the cruise control motor and the engine.
The cruise control motor or acuator operates off vacuum normally, and is usually connected directly to manifold vacuum. So as you go up a hill and need more throttle, manifold vacuum goes down, making it impossible for the cruise control to open the throttle fully.
Installing a vacuum check valve keeps the vacuum high at the cruise control motor. An accumulator inline between the check valve and the cruise control motor helps ensure sufficient quantity of vacuum to fully open the throttle.
Old Mar 19, 2004 | 07:25 AM
eric-the-red's Avatar
Lack of power on a 2nd gen, nooooo waaay
Old Mar 19, 2004 | 08:03 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
HAHAHAHAHAHA!!!!!!!!!!
Old Mar 19, 2004 | 09:40 AM
WSU4runner's Avatar
Mine does the same thing. It does it when I would normally downshift. Now I just anticipate those hills and then put it back into cruise control after I climb it. Our trucks are way too slow
Old Mar 19, 2004 | 11:01 AM
Yoter's Avatar
Guest
I understand what your saying about the throttle being wide open and the ecm shutting it down. I know I dont have performance issues. My shiznit up and goessssssssssssss.
shisha1999
Sep 21, 2015 08:22 PM
kirkrunner
Jul 27, 2015 07:59 PM
jake_v
Jul 22, 2015 03:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
rushw
Jul 18, 2015 01:46 PM
