Whirring sound after transfer case oil change?
Old Dec 20, 2006 | 06:33 PM
GhostriderTx's Avatar
I changed the transfer oil on my 2001 4Runner with 75w90 dino. While driving after I put it in AWD and I swear I hear a whiring sound that I didn't have before. I am not sure since I rarely use AWD and totally unclear how it icould be related to the transfer case oil change. Any ideas? It has 65 K and case was changed by dealer at 20 and 40 K. The only other thing I tried to do was change the front diff. This failed since the drain plug is apparently welded on. I did some serious pulling on it before quiting
Old Dec 21, 2006 | 04:21 AM
rearviewmirror's Avatar
Double check the fluid level and the type of fluid you put in there. There's not much that can go wrong with a fluid change if the level and fluid type are correct. I just changed all the drivetrain fluids in my 2000 this past weekend too, I used Mobil1 75W-90 Synthetic gear oil in both diffs and xfer case.
smthwsn357
May 1, 2024 07:28 AM
crashburnoveride
Jul 10, 2015 06:39 AM
horunner1x
Jul 10, 2015 06:33 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
