where to put the jack in the front?
Old Dec 8, 2003 | 09:33 PM
ddua's Avatar
Question where to put the jack in the front?
I am planning to change my oill
But I don't know where to put the jack under there
Picture will greatly help because I am NOOB with my rig
Pllzz helppp......
Thanks
P.S:I don't even know which one is lower control arm
Old Dec 8, 2003 | 09:40 PM
Darren's Avatar
I would venture to say that you would be able to change the oil easily enough without rasing the front end. This isn't a car. Instead of jacking the thing up, go buy some ramps for $15, or whatever they are. They can only be safer anyway.
Old Dec 8, 2003 | 09:41 PM
doink's Avatar
why would you need to jack up your rig to change the oil?
Old Dec 8, 2003 | 10:26 PM
ddua's Avatar
hehehe that's why I said i am noob with my rig
This is my first rig
I didn't know that we don't have to jack up the front to change the oil
Thanks for the help
Old Dec 8, 2003 | 10:30 PM
GoudyMan's Avatar
ramps work best
Old Dec 8, 2003 | 10:36 PM
ddua's Avatar
I assume when you use ramp , u put stopper at the rear wheel ?
where can i get ramp ? do sears, autozone have them ? price range ?
Thanks
Old Dec 8, 2003 | 10:38 PM
Bob_98SR5's Avatar
ddua,
heard of an owner's manual? the jack points are detailed in there. don't have one? then buy a chiltons or haynes at your auto parts store.
also, check the tech section here. i have a write up specifically addressing your question. also, you dont need to get ramps or jack up the truck if the following conditions apply:
- you have 16" wheels
- you're not obese and cant slide under your vehicle to remove the drain plug.
bob
Old Dec 9, 2003 | 04:58 AM
Toyminator's Avatar
Ha...lol
Old Dec 9, 2003 | 05:24 AM
44Runner's Avatar
Thanks
In addition to you just plain not needing them, I find ramps to be a PITA personally. I have never thought them to be as safe as carefully used jacks and jack stands either.
Lucky for you, you don't have to worry about any of this. The 4Runner is high enough off the ground where you don't need to raise it to get under it. Best of luck with your oil change...
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
jerusry
Oct 19, 2015 05:28 PM
