where o' where are the Optima 34R's?
Old Feb 25, 2005 | 05:27 PM
f16fxr4real's Avatar
I have been ALL OVER Las Vegas trying to find one and noone says they can even order one. Autozone, Carquest, Checker, local parts stores. They all say Optima just send them 4 or 5 models none of which are the reverse post ones. Anyone have a good line on them?
Old Feb 25, 2005 | 05:38 PM
waskillywabbit's Avatar
TNA Sports
http://tna-sports.com/index.cfm?fuse...owse&id=100041
Old Feb 25, 2005 | 07:44 PM
Thanks
just placed my order for the "orange" top
read......now comes with red top
Old Feb 25, 2005 | 08:04 PM
ldivinag's Avatar
yeah.. the orange toppers (reversed) are now red.
Old Feb 25, 2005 | 08:08 PM
Glad to be of service.
Old Feb 25, 2005 | 08:14 PM
Localmotion's Avatar
not to hijack...but what part number is the yellowtop for a 3rd gen
Old Feb 25, 2005 | 08:16 PM
ugadawg95's Avatar
Summit Racing has 'em for $115.39 + $8.95 SH = $124.34
Part Number: ULT-9003-151
(Bottom of the page)
http://store.summitracing.com/defaul....asp&x=15&y=13
Don't forget to ask for the spacer.
Part Number: ULT-242-0018
Old Feb 25, 2005 | 08:17 PM
There's no part number per se for a 3rd gen, it is just a battery. If you want a Yellow Top, I say get the D34/78...you just want a basic yellow or red, but if you are cranking get red, running lots of accessories get a 2nd yellow w/ the red
Old Feb 25, 2005 | 08:23 PM
i just wanted the yellow for the extra poles....ive got 4 hellas and 2 piaas
Old Feb 25, 2005 | 08:26 PM
is there a yellow top 34R?
Just run your lights off an auxiliary fuse box like I had on my 3rd gen, cost like $10 at the local parts place and was an easy mod. Never had a problem.
Old Feb 25, 2005 | 08:34 PM
Look on that website link in my first post...they got them all and pretty well laid out as to what is what...
Old May 20, 2005 | 11:31 AM
Randomness's Avatar
Ok, so just to clarify for me...2nd gen 4runner's need a Reversed pole battery? This means the Pos/Neg terminals are on switched sides from a "normal" battery? Which Red Top does a 95 3.0 need? This is confusing
Old May 20, 2005 | 01:08 PM
ldivinag's Avatar
no... 2nd gens need the regular one...
you just need a way to space it if you use the stock battery hold-down bracket...
Old May 20, 2005 | 01:35 PM
Eric's Avatar
I saw a red top at costco yesterday for $99, anybody know how this works in a 2nd gen?
Old May 20, 2005 | 01:37 PM
ROMAD's Avatar
^^ I am using a Blue top from Costco (starting/charging Marine...pretty much a Red top with extra poles) in my 95 4Runner for almost a year now and it works like a champ
Just be sure to get the spacer for the battery - you might have to call Optima for it but they will send you one for free if you ask.
Old May 20, 2005 | 07:43 PM
Randomness's Avatar
Romad...at the moment, I'm following your 'heavier gauge battery wire' write up, dealing with electical problems. I have a couple questions... How do I get that 80A alternator fuse out? Do I even need to, cuz I just wanted to make sure it's not blown, and I couldn't really tell just by looking at the top of it, I don't think? That thing is a pain to get to, so I'd hate to do it all again. Also, I suck at soldering, but I got a bunch down on the new wire, and got the crimp on it, do you think it will be ok? Thanks!
Old May 21, 2005 | 09:31 PM
ROMAD's Avatar
You have to get the fuse out to to the mod - the fuse comes out the bottom of the whole assembly. (from memory) the assembly is bolted to the fender and/or/also it is a slip fit on the brackets to the fender.
What you need to do is look around the perimeter of the bottom side of the assembly (the box that is holding the fuse and several other relays and the like) and notice that the bottom side can be removed.
You need to gain access to the fuse by removing the bottom of the relay box assembly and then the fuse will push out from the top side, down, and out the now open and exposed bottom. There may be some little 'arms' that need to be squeezed in on the top of the fuse to get it to slide down - it sounds more complicated than it is. Just look at it and it should make sense.
0 - DISCONNECT THE BATTERY!
1 - gain access to the bottom of the fuse/relay box
2 - remove the bottom of the fuse/relay box
3 - remove the fuse out the bottom and then begin to note the position and location of all the wires on the fuse so you can do the upgraded wire mod.
Let me know if you see improvement after you do this - it fixed every one of the problems I had as well as adding a noticeable amount of pep in the low to mid range part throttle acceleration.
Good luck!
Its really easy, just go slow and look at things closely and you will see how simple it is.
Here is the link to the original mini write up
Old May 22, 2005 | 07:00 PM
Randomness's Avatar
Yeah, I followed your write-up, and finished Friday night. Totally fixed my problem! Run's like it should now Thanks so much for doing that write-up, you really saved me a load of cash!
Old May 23, 2005 | 09:45 AM
Eric's Avatar
link to writeup?
