wheelwell/frame liner
Old Sep 10, 2004 | 08:25 AM
TeamShiftPoint's Avatar
I did a 2" body lift on my 90 4runner. now the frame is exposed and you can see thru to the other side where the frame and body gaps.
where can i find those flat panels/sheets of liner to i can use to cover up and make it look alittle better? I'm pretty sure I can cut it into shape or sizes I need.
thanks
William
Old Sep 10, 2004 | 08:29 AM
boogyman's Avatar
Talking
i've heard that pond liner works well.. you can get that at lots of hardware or gardening shops.
-Russell
Flamedx4's Avatar
NOrthwest Offroad sells replacements that are taller for body lifted rigs. Around $50 a set if I remember correctly.
Old Sep 10, 2004 | 08:36 AM
-Russell
yea, i was thinking about some building material stuff, like the black/gray stiff plastic that they sometimes use on the outside of a house frame. before they put up the siding or bricks.
Old Sep 10, 2004 | 07:30 PM
Flamedx4's Avatar
The stuff they wrap houses with is supposed to be something like Tyvec, but it sounds like you're talking about 6 mil visqueen (used for vapor barrier under the crawl space in home construction.) Not nearly thick enough. Flapping in the breeze and pulling loose will look bad, those gaps look fine (who the heck looks into fenderwells anyhow?) but it you want to fill those gaps you need something sturdy. What you need is as thick as cardboard. Maybe rubber mats, something like that.
Old Sep 10, 2004 | 07:55 PM
Susquehanna Motorsports sells 1/8 inch urethane by the square foot that should work quite well.
Old Sep 10, 2004 | 08:11 PM
yeah, that stuff looks pretty good
http://www.rallylights.com/Rally/mud_flap.asp
need to find some stuff like that locally.
Old Sep 11, 2004 | 06:53 PM
914runner's Avatar
From what I hear, NWOR is not the best in the customer service department.
Old Sep 11, 2004 | 07:24 PM
grams72's Avatar
Why not try some Diamond plate, You can cut it with a jig saw and screw it to the frame.
Any DIY home center should have it
Old Sep 11, 2004 | 08:18 PM
Birdman's Avatar
I just did a 1" RB BL and made new liners for my rig. I bought 1/16" rubber sheeting at OSH for $9.99 for like a 24"x40" sheet. I traced the old ones and an additional inch. I have pics and I am working on a writeup as we speak. I hope to have them up sometime by tomorrow. Stay tuned. They came out nice.
Old Sep 12, 2004 | 11:19 PM
Birdman's Avatar
Ok, I'm still working on the writeup but here's a few pics of the wheel well liners I fashioned out of 1/16" bulk ruber sheet
http://www.jaderunner.com/Auto/4runn...t/IMG_2686.jpg
http://www.jaderunner.com/Auto/4runn...t/IMG_2687.jpg
http://www.jaderunner.com/Auto/4runn...t/IMG_2688.jpg
http://www.jaderunner.com/Auto/4runn...t/IMG_2695.jpg
http://www.jaderunner.com/Auto/4runn...t/IMG_2697.jpg
Right side finished
http://www.jaderunner.com/Auto/4runn...t/IMG_2699.jpg
Left side finished - copied rear cover from right side and replaced plastic hinged cover
http://www.jaderunner.com/Auto/4runn...t/IMG_2701.jpg
Closeup of left side replacement for plastic cover
http://www.jaderunner.com/Auto/4runn...t/IMG_2700.jpg
Old Sep 12, 2004 | 11:51 PM
jimbo74's Avatar
need to get me soem of that sutff for my bed... the front looks ok, becasue its still dark, so you dotn really notice it, however the rear since its a pickup has a huge gap back there
Old Sep 13, 2004 | 10:56 AM
Birdman's Avatar
The rear doesn't look to bad on mine after only an inch of lift. I decided that the work outweighed the benefits so I'm leaving it as-is.
However, the front needed the work:
And it looks much better this way:
terminator
Oct 13, 2021 10:13 AM
A2theK
Sep 30, 2016 12:50 PM
87SR5justin
Sep 29, 2015 02:50 PM
ViperTT
Aug 14, 2015 05:27 AM
Peach
Jul 3, 2015 09:30 AM
