Wheels, 4thGen, Konig and offset, size.
Old Feb 21, 2004 | 07:25 AM
JGage's Avatar
Talking Wheels, 4thGen, Konig and offset, size.
fourunnabilly and all,
You said your rims would fit the stock 17" 265 tires. But, Toyota lists their size rims as 17x7.5 with a 30mm offset. The Konig's are 17x8.5 with a 20mm offset.
Does everyone agree it's safe with those differences and there won't be any side effects ? (ie: rubbing, weirdo speedo readings, ect.)
Old Feb 21, 2004 | 08:53 AM
FirstToy's Avatar
The Sport Edition wheels have a 25mm offset (it's stamped into the back of the wheel) so I'm going to assume the other styles are also 25mm. I guess it doesnt really matter.
8.5" is pretty wide for a 265. Maybe 285 would be better for the wider wheel.
Lefty has 265's on AR 17x8 with 0 offset and some minimal rubbing at full turn.
Old Feb 21, 2004 | 05:03 PM
JGage's Avatar
I did some more checking and Tire Rack says the stock tires will fit the 8.5 just fine.
foampile
Dec 18, 2022 01:29 PM
jgallo1
Oct 26, 2015 06:39 PM
kouki420
Sep 2, 2015 11:42 AM
TDonkey
Jul 26, 2015 10:14 AM
