VAF Problem
Old Feb 21, 2004 | 09:47 AM
Sheemie's Avatar
VAF Problem
Hi, I need some advice on an airflow meter problem. I have a 95 4runner, 4WD V6, and with the engine running, I'm reading 20 volts AC between the meter housing and ground. I've replaced the airflow meter, still same problem, and the alternator diodes test good and no AC is detectable between alternator output and ground. Any ideas would be appreciated...
Old Feb 21, 2004 | 04:05 PM
lunatic14r's Avatar
whats the problem your having with the truck??
Old Feb 21, 2004 | 05:39 PM
Sheemie's Avatar
Sluggish at low RPM, low fuel economy (10-13 mpg). Gives a trouble code for both airflow meter and Air Temp Sensor. Thanks.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
