Wheel spec difference between '97 & '98? (Tacoma)
Old May 15, 2006 | 03:31 PM
Cardiac's Avatar
I've been looking for new wheels for the '97 Tacoma I'm buying, and I keep reading things like:
"Wheels will fit: '98-'06 Tacoma, Tundra (thru '06), '86-'06 4Runner, Sequoia (thru '06)"
"What will these wheels fit on? Wheels will fit 4Runner ('98-'06), Tacoma ('98-'06), Tundra (thru '06), and Sequoias (thru '06)."
Is there a reason that a late model six lug Toyota truck wheel will not fit my '97?
Old May 15, 2006 | 07:55 PM
KyleT's Avatar
only backspacing, you might have to run spacers. I run 1.5" spacers with my GX470 rims. same offset as sequoia, tundra and the new 4runner and tacoma.
Old May 16, 2006 | 07:09 AM
hupptoy's Avatar
If the wheels will fit a 98, then they will fit your 97 assuming you have OE 15" wheels. If you have OE 16" wheels and the larger brakes, then you need at least 16" wheels. Not sure what year the bigger brakes became optional.
I can take the wheels off of my 99 and put them on my 93 without issues, so you should have no problems on your 97.
hupptoy
Old May 18, 2006 | 03:23 PM
Cardiac's Avatar
Good to know. What is the difference between offset and backspacing?
Old May 19, 2006 | 04:31 AM
hupptoy's Avatar
Offset: http://www.tirerack.com/wheels/tech/...jsp?techid=101
Backspacing: http://www.4crawler.com/Diesel/Tires.shtml#WHEELS
The 2nd link also compares offset and backspacing which are measuring the same thing but stating it in different ways.
hupptoy
Old May 20, 2006 | 10:47 AM
Cardiac's Avatar
Thanks again. Backspacing is what I thought offset was...
Flying91
45
Apr 11, 2024 04:39 PM
Sleaker
Aug 26, 2020 06:03 AM
Yotoder865
Jul 9, 2015 07:51 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
