wheel spacers
Old Sep 16, 2002 | 03:36 PM
teddy's Avatar
wheel spacers
I saw some wheel spacers on the web shopping and I thought about getting some so that maybe I could get some wider tires.
has anyone used them? and do spacers cause problems?
Old Sep 16, 2002 | 06:15 PM
mysticpur's Avatar
I've never used them, but a friend once had some custom made to accomadate a set of 8.5" wide wheels on his '84 SAS. The wheels were for a IFS Toy, and when mounted on the '84, the wheel pressed snugly against the tie rod, and locked down the front. Bottom line was that they did infact space the wheel away from the tie rod, but due to the "custom" made spacers, he was never able to achieve a balenced front ride. I suggested try to secure them to the wheel using a good epoxy, so that the spacer would be on the wheel, and then rebalence, but he just went with a different wheel.
Old Jan 20, 2004 | 11:57 PM
tenfourtyeight's Avatar
I'm researching these for a freind, and this was the best I could find searching.
Can anybody tell me more about them? Safe? Practical? Opinions?
Gracias. :beaver:
Old Jan 21, 2004 | 06:11 AM
RTdawgs's Avatar
http://www.pirate4x4.com/forum/showt...hreadid=200758
Old Jan 21, 2004 | 06:14 AM
beachtaco's Avatar
just get the bolt on style spacers, not the slip on ones. i ran a set of bolt on spacers on my taco and never had a problem with them, on or off road.
Old Jan 21, 2004 | 08:46 AM
Cool, thanks guys. I was mostly wondering if they could have any ill-effects on parts of the axle, wheel, etc.
Old Jan 21, 2004 | 11:45 AM
RTdawgs's Avatar
just the same as a wheel with less backspacing.
Old Jan 21, 2004 | 02:21 PM
toy283's Avatar
Which could mean premature bearing failure. Anytime you move the wheel centerline away from the bearing centerline this is a possibility. The whole idea of the original wheel offset is to keep these two centerlines as close together as possible. Deviate significantly from this and the stress loading on the bearings changes enough to possibly cause premature failure.
K. Now that I've spoken the manufacturer gospel, I've had signifcantly altered offset for fifteen years without any problems. Just be sure to use the bolt-on style spacers as previously stated.
Old Jan 21, 2004 | 02:32 PM
Fink's Avatar
So does that mean its bad to have a set of aftermarket wheels with different backspacing? Cause I have 15x8 Tech1 Crawlers with 3.5" backspacing...
Fink
Old Jan 21, 2004 | 02:53 PM
Sweet. That's kinda what I wanted to hear, cause I'm thinking of getting them myself. I think my truck would look a lot better with the wheels out a little more.
Thank you all, I've been trying to get a straight answer from many people about this, and all anybody would tell me was, 'it's not safe' and leave it at that. I wanted to know why, and I finally found an answer.
Gracias. :beaver:
punks_is_4x4
Aug 21, 2015 01:35 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
