What's the name of this part?
Old Nov 20, 2003 | 12:07 PM
UKMyers's Avatar
Excuse my ignorance on this but thought I would sound dumb here and not at a shop. I need to know what the name of a part is. Okay there's the tie rod end that goes to the idler arm. Then there's another rod with a joint on the other end that goes from the idler arm to the steering linkage. The bushing where it goes into the steering linkage is about shot on mine and I'm thinking it was because the idler arm was bad. Anyways does anyone know what this would be called?
Old Nov 20, 2003 | 12:12 PM
AznSky's Avatar
Sorry, it seemed like a perfect time
Old Nov 20, 2003 | 12:14 PM
Dr. Zhivago's Avatar
Away
That part is called the center link.
Hope this helps.
G
Old Nov 20, 2003 | 12:37 PM
UKMyers's Avatar
Thanks DR Z! Toyo I used to post pics galore but I killed my digi cam a while back and haven't gotten a replacement.. Digi cam-0 Concrete-1
Old Nov 20, 2003 | 06:01 PM
Away
Originally posted by UKMyers
Thanks DR Z!
YW! Glad you got home safely.
Peace!
G
Old Nov 20, 2003 | 06:11 PM
Cebby's Avatar
Re: What's the name of this part?
I could be wrong (open mouth - insert foot), but aren't you saying a bushing of some sort is bad? The center link is the bar that is connected to the stabilizer and the tie rods (?). The center link does not have any bushings as a part of it and I doubt it would go bad. Joey, the center link is what I had to replace cause the dumb a$$ that I am - I drilled out the stabilizer hole when I went to put on my OME (live and learn...)
Old Nov 20, 2003 | 07:02 PM
FattyCBR's Avatar
I agree with Cebby, to me it sounds like you're describing a tie rod end (TRE) or a cone washer.
Old Nov 20, 2003 | 07:25 PM
UKMyers's Avatar
Okay Ceb the part I am talking about is the piece that goes into the centerlink then on the passenger side. It basically looks like a tie rod end just it's on the opposite side as the wheel. Tie rod end, idler arm, mystery piece..........
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
