What is this wire for?
Old Jul 6, 2006 | 06:10 AM
mt_goat's Avatar
I'ts on a 2001 5VZFE, I got the intake off to put the supercharger on and there is this little short wire:
http://community.webshots.com/photo/...42310107myszCL
I'm wondering if it is a knock sensor wire, because I remember on the 3.0 it was a good idea to replace it anytime you did the headgaskets.
Old Jul 6, 2006 | 06:16 AM
Beast's Avatar
was it hooked up before
toyota has "extra" plugs
check in your wiring diagram and id the color code
Old Jul 6, 2006 | 06:29 AM
MTL_4runner's Avatar
That's the ECT (engine coolant temperature) sensor wire.
Knock sensors are under the lower intake plenum.
Old Jul 6, 2006 | 06:31 AM
mt_goat's Avatar
Yes it was connected to the engine harness near the where the fuel injector plugs are. I know how to hook it back up, but I'm wondering if it is a knock sensor wire and should be replaced. The fact that it is only about 4 inches long and has plugs at both ends makes me suspect it is meant to be replaced like the knock sensor wires on the 3.0?
Old Jul 6, 2006 | 06:34 AM
mt_goat's Avatar
Knock sensor is under the lower intake plenum.
Oh thanks Jamie, anyone replacing these or will they last a long time?
Old Jul 6, 2006 | 06:37 AM
I'd leave it, but you can take it out and test it in a pot of hot water and measure the resistance (from the terminal to the body of the sensor) if you are concerned about it. The sensor should be fairly linear in resistance change vs water temp.
Old Jul 6, 2006 | 06:43 AM
mt_goat's Avatar
Ok thanks Jamie, I won't worry about it.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
