what tire size? 1990 4runner
Old Dec 11, 2004 | 06:24 PM
TeamShiftPoint's Avatar
what tire size do most ppl run on their rigs?
I have a 1990 4runner 4wd with a 2" body lift. I'm running the stock 16" wheels from a newer sequoia/tundra 16x7
I want something around 32's but I not sure what the size will be. I dont think they sell sizes like 32 1150 in 16" diameter sizes. I want beefy tires. not skinny ones that will look weird with my lift.
TIA
William
Old Dec 11, 2004 | 06:26 PM
also whats the largest tires I can run without rubbing issues?
Old Dec 11, 2004 | 11:09 PM
SolidDigital's Avatar
265 75 R16 = about 31.6 x 10.4" depending on the tire brand.
A 32 x 11.5" bfg all terrain is actually 31.7" tall, so 31.6" is basically a 32" tire.
with a 2" lift I'd say you could pretty easily fit 285's under there though.
285 75 R16 = roughly 32.8 x 11.2"
Old Dec 12, 2004 | 11:34 AM
thanks for the info. I probably will go with the 285-75-16
Old Dec 12, 2004 | 11:43 AM
outdoorfever's Avatar
what did you have to do when you went from 15 inch wheels to 16? change the brakes or anything special? they look so much better than those puney 15's. good luck.
Old Dec 12, 2004 | 02:15 PM
i didnt have to do anything to run the 16's
wheels are wheels. you just have to get the right offsets and bolt pattern. and choose tires that will not cause rubbing.
you can put 20's on your 4runner if you even wanted.
I'm actually running 17" stock toyota wheels from a new tundra limited right now. I'm about to swap those over to my sequoia, and take the sequoia 16's.
Old Mar 6, 2005 | 09:26 AM
Sequoia'd's Avatar
When I bought new wheels for my Sequoia, I mounted the old '01 Sequoia wheels on my '91 4Runner. They are 16" and the fit perfectly!! Also went with 275-75-16 Nitto AT's... no lift on 4Runner and they are 31.68" tall. No rubbing and they look really good!
Old Mar 6, 2005 | 12:06 PM
birfieldwheer's Avatar
Being the red neck that I am, I dont get the non traditional system of tire mesurement (31, 33, 35, 38, 44s...). Will some one explain this to me?
Old Mar 6, 2005 | 12:07 PM
i.e. What the heck is 275-75-16 actually measuring and in what units.
Old Mar 6, 2005 | 10:40 PM
ATP4984's Avatar
I'm glad someone else asked that first, any takers? I'm running the stock wheels on a '93 4Runner, how big a tire can I buy? 32"? If anyone wants to offer a Tires 101 class, I'd be appreciative.
Old Mar 6, 2005 | 10:58 PM
jimbo74's Avatar
275 is tread width in millimeters
75 is the apect ratio percentage of sidewall to tread width
16 is the diameter of the rim
here is a formula to figure out total outside diameter (converting to the standard 31x10.5x15 size type measurement)
(75% of 275 mm = 206.25) x 2
25.4 (as there are about 25.4 mm in 1 inch)
now multiply that result by 2 and you have the full sidewal height (mutiplied by 2 because there is a top and bottom area of the rim as its surronded with sidewall
add the 16" rim
the tire size of 275/75/16 equates to being a 32.24" outside diameter/tall tire
the width is 275 mm, so that would and can be converted like this:
275 (tread width in mm)
25.4 (mm per inch)
this part doesnt look like an equation but it is: 275 divided by 25.4 = 10.82" wide
275/75/16 = 32.5x10.8x16 or very close
Old Mar 7, 2005 | 05:24 PM
Thanks i get it now.
Next question why the heck dont they do it the easy way?
HE HE HE HE HE
I love this site. No one can flame me!
Old Mar 7, 2005 | 09:24 PM
green91runner's Avatar
cause someone thought that metric would be easier.. multiples of 10 based off a metre. can't remember how they came up with what should be a metre, but i do remember that it was some non-scientific, really stupid way..
Based off this site your days are numbered till your forced to learn the metric system too.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Whatever123
Sep 30, 2015 12:12 AM
ptb12
Jul 5, 2015 01:49 PM
